my log transfer
Started by mdobuk21, February 10, 2015, 08:18:03 PM
mdobuk21
Alan, thankyou so much for your help, I thought if I logged in as the administrator that would help and it certainly did, I am now back up and running!!
Mark
Aerotower
#17
Hi guys,
My mylog have 209,705kb, and I only have 13457 new aircrafts.
I think that mine have a problem.
Not necessarily.  It depends how many movement information each looged airframe has.
I have a little over 30000 airframes per year. But some airframes have over thouthand movements logged. That is why my mylog breaches the 500MB threshold every one and a half year.
I bet your Mylog has been running for a good number of years Aerotower and as such will have recorded every detail of each aircraft that has been picked up by you over that time.  It holds a lot of info not just about the aircraft but also when you saw it, its flight ID, route, start and finish altitudes etc, etc
It may be a good idea to delete the old data now and again through MyLog Tools and maybe even the photos there.
Aerotower
Since 2009, now I have delete old data but the file still have 209Mb.
I noticed the same. Although starting ANRB was faster, MyLog.db file size remained as big as before.  Maybe another's another bug of V5.00.7x. Sorry forgot to tell then.
I wonder how old the data has to be before it is considered old.  I will log it anyway.
As far as I remember you can select a date and all data before this date will (shall) be removed.
