my log transfer
Started by mdobuk21, February 10, 2015, 08:18:03 PM
mdobuk21
hi
I need to transfer my log database from laptop to desktop pc. is it just a case of copying the data folder and transferring via usb stick to radarbox file on new pc and replace this with data folder on desktop.
mark
In the Data folder you will find MyLog.db3 copy that one across and replace the existing
mdobuk21
is the mylog.db3 file or mylog.db3.bak file alan?
The .bak file was used in older Versions (4.0X or 3.XX), but is not longer used in V5.00.0XX. Therefore you don't need to copy it.
Only MyLog.db3 is needed.
mdobuk21
thanks guys, I have tried this but my log in version 5.00.072 is showing 58 aircraft when I have over 10,000 entries!! I have copied my data file from laptop and replaced it with version 5 but not showing my updates?
mark
You may considering to use the windows search on your laptop. Maybe there is another instance on that computer.
Further you can try to copy out the .bak file and remove the .bak so it reads MyLog.db3. Maybe the original mylog.db3 got corrpted somehow.
Mark,
As Ingo, states you may have more than one instance of the RB software on your computers especially if you have updated rom the original version.  You will have more than on MyLog.db3 file on your computer in this case
MrParanoia
On my Windows 7 laptop I have installed the software into its default location:
C:\Program Files (x86)\AirNav Systems\AirNav RadarBox\Data\
But my data files are updated in this location:
C:\Users\MyWindowsUsername\AppData\Local\VirtualStore\Program Files (x86)\AirNav Systems\AirNav RadarBox\Data\
Radarbox 3D, GlobeS RTL1090, ModeSMixer2, UBC800XLT, UBC125XLT
You are better not to install to the default location as the virtual store can cause problems.
mdobuk21
Hi guys thanks for the replies. I have checked to see I have only one my log file in my data folder and I do but it still does not show all my entries that I have! Not sure what else I can do?
Mark
Mark
Confirm you only have one instance of Airnav software on your computer.  If you started off with 2009, V3.13 or some other from the disk which came with your box and then upgraded to V5 you will have more than one instance therefore you will have more than one data folder and are only looking at the wrong one.
The only way you will have only one data folder is if you fresh installed V5 onto a computer which hadn't had Airnav software on it previously.  If you have more than one data folder you will have more than one MyLog.db3 file.
Use the search facility to look for all instances of MyLog.db3
mdobuk21
Hi alan
Yes i only have one copy of radarbox on my desktop pc, i have the 5.00.072 version freshly downloaded as this is a brand new pc. I copied the data folder from my previous verison of RB version 3.?? Which was on a laptop and replaced the data file on the new desktop pc, i deffinateley have only one version of radarbox and one mylog file!
Mark
Mark,
On your laptop that you were copying your mylog from is that the same, you only have one instance of RB software.
What size and date is the one on your laptop?
mdobuk21
Hi Alan
Thanks for the replies. The size of mylog.db3 is 49.251 kb 8/2/15
Mark
Mark,
That would appear to be OK Mark, mines is only 13,244 kB
