Unable to connect to server from about 0700 this morning
Started by JerryUK, June 01, 2017, 11:02:17 AM
JerryUK
I have not changed anything here - feeding from RPi  - Any ideas?
[2017-06-01 07:01:57]  ******** Statistics updated every 30 seconds ********
[2017-06-01 07:01:57]  Packets sent in the last 30 seconds: 3047, Total packets sent since startup: 3216055
[2017-06-01 07:02:28]  ******** Statistics updated every 30 seconds ********
[2017-06-01 07:02:28]  Packets sent in the last 30 seconds: 0, Total packets sent since startup: 3216055
[2017-06-01 07:02:46]  Connection established.
[2017-06-01 07:02:56]  Could not start connection. Timeout.
[2017-06-01 07:02:59]  ******** Statistics updated every 30 seconds ********
[2017-06-01 07:02:59]  Packets sent in the last 30 seconds: 0, Total packets sent since startup: 3216055
[2017-06-01 07:03:30]  ******** Statistics updated every 30 seconds ********
[2017-06-01 07:03:30]  Packets sent in the last 30 seconds: 0, Total packets sent since startup: 3216055
Last check a few minutesa go
pi@piaware:~$ tail -f rbfeeder.log
[2017-06-01 11:01:06]
[2017-06-01 11:01:12]  Connection established.
[2017-06-01 11:01:22]  Could not start connection. Timeout.
[2017-06-01 11:01:37]  ******** Statistics updated every 30 seconds ********
[2017-06-01 11:01:37]  Packets sent in the last 30 seconds: 0, Total packets sent since startup: 0
[2017-06-01 11:02:08]  ******** Statistics updated every 30 seconds ********
[2017-06-01 11:02:08]  Packets sent in the last 30 seconds: 0, Total packets sent since startup: 0
[2017-06-01 11:02:24]  Can't connect to AirNav Server. Retry in 60 seconds.
[2017-06-01 11:02:39]  ******** Statistics updated every 30 seconds ********
[2017-06-01 11:02:39]  Packets sent in the last 30 seconds: 0, Total packets sent since startup: 0
Jerry,
As far as I am aware the server is OK, not many forum users are wise to Pi.  Maybe drop a line to [email protected]
JerryUK
Thanks Alan, I have sent them a mail drawing their attention to this posting. Meantime if anyone else has suggestions, fire away!
JerryUK
And now it's working again.....
But number of aircraft shown on the map looks severely decreased?
And now the flight list is empty.... I think I give up
This should be ok now. Our developers are keeping a close eye on the connections at the moment.
JerryUK
I am in the middle of a complete reinstall of all my feeders now that I have done a complete reinstall of the RPi. I will check as soon as I am able.
JerryUK
Sorry to report still no aircraft showing despite log entries showing I am sending traffic:-
pi@pi:~/adsb-exchange $ tail -f /var/log/rbfeeder.log
[2017-06-01 15:08:40]
[2017-06-01 15:09:11]  ******** Statistics updated every 30 seconds ********
[2017-06-01 15:09:11]  Packets sent in the last 30 seconds: 2929, Total packets sent since startup: 92143
[2017-06-01 15:09:42]  ******** Statistics updated every 30 seconds ********
[2017-06-01 15:09:42]  Packets sent in the last 30 seconds: 3010, Total packets sent since startup: 95153
[2017-06-01 15:10:13]  ******** Statistics updated every 30 seconds ********
[2017-06-01 15:10:13]  Packets sent in the last 30 seconds: 3128, Total packets sent since startup: 98281
[2017-06-01 15:10:44]  ******** Statistics updated every 30 seconds ********
[2017-06-01 15:10:44]  Packets sent in the last 30 seconds: 2978, Total packets sent since startup: 101259
JerryUK
EXTRPI000473
The red/green bars on the bottom left of the webpage is showing me offline as well
I checked my Pi3:
- Aircraft are currently displayed on RB24 website
- Uptime status window is showing an offline time from 4:00 UTC until 10:00UTC today. FR24, Planefinder, Flightaware were showing no outage. --> Offline time was caused at AirNavs end.
Seems that the problem is fixed for me.
I checked about RPI feeder in Germany. Approximately 20% showing the same offline time as mine did.
It looks offline to me Jerry.  https://www.radarbox24.com/stations/EXTRPI000473  Other Pi's are showing OK, maybe support can assist.
Jerry,
In a previous similar occasion a Pi feeder stated Did a reinstall and my key changed- entered the new key in and it is working
JerryUK
I am purging the rbfeeder and going to try installing it with another key
JerryUK
Ok so that new key worked, I appreciate your insight Alan.
Is it possible to my old key back from the original install when it was working? It's obviously gone now from my RPi.
