Author Topic: White Cross  (Read 11327 times)
westiev8
White Cross
« on: February 11, 2019, 12:51:58 PM »
Hi All... when I put the mouse cursor over a plane in the map it just stays a cross and does not high light the aircraft, I'm on 6.02.003
with a microRB...thanks
Re: White Cross
« Reply #1 on: February 11, 2019, 01:53:59 PM »
I have not updated to V6.00.03 as it is solely to allow the X-RANGE receiver to work with the software,  Delete your installation and install 6.00.02 http://www.airnavsystems.com/download/ANRB/ANRB60002Setup.exe and you will not have any issues
westiev8
Re: White Cross
« Reply #2 on: February 11, 2019, 07:00:33 PM »
cheers ... works perfect
westiev8
Re: White Cross
« Reply #3 on: February 11, 2019, 07:04:49 PM »
my next question... radar box flightstick with windows 7... the software will not start up with the flightstick connected?
Re: White Cross
« Reply #4 on: February 11, 2019, 07:45:57 PM »
No idea on why that should be the case, I just plugged it into the PC I am typing this reply on and its working fine and it is Windows 7
My Micro RB is usually plugged in but plugging in the flightstick saw Windows installing drivers for it so I had to install the Zadig drivers again
« Last Edit: February 11, 2019, 07:56:33 PM by Runway 31 »
  • CYYZ - Toronto
Re: White Cross
« Reply #5 on: February 11, 2019, 09:56:42 PM »
You have to install rtl-sdr driver zadig
Is My DVB-T RTL SDR Dongle Healthy?
Go to  OPTION-1, and carry out "STEP 1 of 3" ONLY.
« Last Edit: February 12, 2019, 03:28:53 AM by abcd567 »
westiev8
Re: White Cross
« Reply #6 on: February 12, 2019, 12:23:38 PM »
in the drop down menu it didn't list RTL2838 it came up with "bulk-in" which by removing the dongle said it was.....I've got it up and running now...thanks v much for the help.
