Re installation of radarbox
Started by Melvin2957, June 11, 2017, 06:10:23 AM
Melvin2957
Good morning sorry to trouble you again something happened to my pc yesterday and I have lost my radarbox so it needs installing again .
Last time a nice German man installed it for me as I am useless we used team viewer can anyone help please
Well, the same procedure as last time then?
Melvin2957
Hi Melvin,
remove id and password.
"Congratulation", you are the second known victim of the creators update (version 1703) of Win10.
No you should remove the Temviewer Code from your post. Same counts for Radarbox codes.
Is the RadarBox Hardware connected to your PC? If not connect it please.
Melvin2957
That's bad because I didn't find it in device manager, which means that the system doesn't see it.
I initiated a reboot of your PC via teamviewer. No your PC isn't reachable anymore.
Melvin2957
Do you need me to connect to team viewer again
Melvin2957
Melvin2957
Melvin2957
Sorry about this I have to go out can you do this later or when you can will be fine thank you Melvin
No problem, I've a week off from work. I'm sure we will find some time during the next few days or even later today.
