I CAN'T INSTALL RBFEEDER ON MY Pi24 RASPBERRY
Started by medlege, March 27, 2019, 08:08:35 AM
medlege
Good morning abcd567 and wiedehopf !
OK abcd567 I followed your instructions and at the moment I can see that everything is back to normal !!!
The only line missing is: log_file=/var/log/rbfeeder.log
Please check the screenshots as required.
My rb feeder is back online with all the 3 others at the same time ! At last !!
I will monitor this during the next days.
Thank you so much again for your precious help and support !
You are really masters !
Best regards !
#76
Quote from: medlege on September 25, 2019, 11:03:24 AM
The only line missing is: log_file=/var/log/rbfeeder.log.
I dont think having the line starting with "log_file=" is necessary, as this is default setting. However you can check if the log file exists in folder /var/log/ and logs are written to it by following command.
sudo nano /var/log/rbfeeder.log
Later addition:
I feel that you dont know how to copy-past text to a file through PuTTY, that is why you did not understand what wiedehopf told, although that was easy. I am attaching an image which explains how to copy-paste text to a file through PuTTY.
