I CAN'T INSTALL RBFEEDER ON MY Pi24 RASPBERRY
Started by medlege, March 27, 2019, 08:08:35 AM
medlege
Good morning to you all !
I'm not an expert using linux at all...
I just strictly followed the instructions on RB24 website (https://www.radarbox24.com/raspberry-pi/guide) to add just the rbfeeder to my Pi24 present raspberry Pi. I want to share my data with radarbox24 here in West Africa.
The rbfeeder is not installed even though I followed the steps one by one as detailled on the website...
I don't know where the problem comes from... At the end I have the message "E: Unable to locate package rbfeeder"
So here is attached all the log extracted from putty.
When I try to check my RB24 key I have the error message "sudo: rbfeeder: command not found"
Please I need your help and support !!
Thanks a lot in advance.
Best regards.
wiedehopf
Try:
sudo apt-get install -y apt-transport-https
then start the installation again.
medlege
Hi !
Thank you for your message and your help.
I followed your instructions but the problem is still there. Impossible to install rbfeeder...
Here attached the putty log.
Regards.
wiedehopf
#3
Try this:
sudo apt-get update
sudo apt-get install -y --force-yes apt-transport-https
sudo apt-get upgrade
Not sure what exactly the problem is.
Maybe you are running a rather old Rasbpian?
This command should show the Raspbian version:
cat /etc/os-release
medlege
Here is my version. It is a Pi24 from flightradar24.
Please check the attached file.
medlege
Its is not working when I type
sudo apt-get update
I have this message:
sudo apt-get update
E: The method driver /usr/lib/apt/methods/https could not be found.
N: Is the package apt-transport-https installed?
wiedehopf
does this work on its own?
medlege
Please check the putty log.
Still got error message...
MDA
@medlege Can you run
cat /etc/apt/sources.list
and post output?
medlege
Hi !
Yes of course.
Please check attached file.
Thanks.
MDA
Seems to be ok.
Can you ping 8.8.8.8 from Pi?
ping -c 1 8.8.8.8
Please post output.
Can be something with DNS.
wiedehopf
#11
It's strange because downloading the installation script from radarbox worked just fine.
so dns in general seems to be working.
Is this an pi24 image?
try this please:
sudo rm /etc/apt/sources.list.d/rb24.list
sudo apt-get update
ping mirrordirector.raspbian.org
and show the output :)
MDA
Probably he uses FR24 image (pi24 in 1st post).
medlege
medlege
Hello to all !
Yes as I told you in my post I want to install RADARBOX24 feeder on my FLIGHTRADAR24 Pi24 raspberry.
But impossible to have it installed so I'm asking for your help and support !
Thanks.
