Radarbox24 - RBFeeder error during install on raspberry pi [SOLVED!]
Started by beeyev, May 24, 2019, 04:07:19 PM
beeyev
User abcd567 solved the problem
Need to install netbase package.
sudo apt update
sudo apt install netbase
Post with solution
I am using DietPi distro for Raspberry Pi 3, it's based on raspbian stretch, i like this distro and have no issues with feeding FR24 or FA.
I need your help to solve the problem, why RBFeeder does not work.
Service crashes with this error:
May 24 18:38:56 DietPi systemd[1]: rbfeeder.service: Service RestartSec=100ms expired, scheduling restart.
May 24 18:38:56 DietPi systemd[1]: rbfeeder.service: Scheduled restart job, restart counter is at 5.
May 24 18:38:56 DietPi systemd[1]: Stopped RBFeeder Service.
May 24 18:38:56 DietPi systemd[1]: rbfeeder.service: Start request repeated too quickly.
May 24 18:38:56 DietPi systemd[1]: rbfeeder.service: Failed with result 'exit-code'.
May 24 18:38:56 DietPi systemd[1]: Failed to start RBFeeder Service.
if i try to start it with key: rbfeeder --setkey fffffff322323323
i got this error:
getaddrinfo: Servname not supported for ai_socktype
[2019-05-24 19:03:02]  Could not resolve host name specified in 'external_host'.
Logs are empty.
How can i fix this? Have you got any ideas?
Please post output of this command
cat /etc/rbfeeder.ini
Note: Replace your actual key by xxxxxxx when posting the output
For your guidance, output of above command on my RPi is given below.
Note: I have replaced actual key by xxxxxxxxxx and station number sn by nnnn
[client]
network_mode=true
key=xxxxxxxxxx
sn=EXTRPI00nnnn
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
beeyev
it's ok, i have already checked
[client]
network_mode=true
key=xxxxxxxxxx
[network]
mode=beast
external_port=30005
Let us try this and see if it solves the problem:
In file rbfeeder.ini, change
To
external_host=localhost
Save file, then restart rbfeeder
beeyev
wiedehopf
For testing, start it on the console:
sudo systemctl stop rbfeeder
sudo rbfeeder
Please post the output.
Also show the output of:
ping 127.0.0.1 -c2
beeyev
same
root@DietPi:~# sudo rbfeeder
[2019-05-25 20:14:04]  Compiled with arch=raspberry
[2019-05-25 20:14:04]  Could not resolve host name specified in 'external_host'.
wiedehopf
How did you create /etc/rbfeeder.ini?
Show the output of:
ls -l /etc/rbfeeder.ini
cat -v /etc/rbfeeder.ini
ping 127.0.0.1
wiedehopf
Just as a test use localhost instead of 127.0.0.1
Best delete the old line and past this one:
beeyev
it did not help, unfortunately.
here is an strace
https://pastebin.com/wz67d9tZ
or in attch, could you please look at it, maybe you will find smth.
What is the output of following command:
cat /etc/hosts
beeyev
127.0.0.1    localhost
127.0.1.1 DietPi
#::1 localhost ip6-localhost ip6-loopback
#ff02::1 ip6-allnodes
#ff02::2 ip6-allrouters
enabling ipv6 does not change anything
wiedehopf
Either you overlooked one of my posts or one of yours got moderated:
I'll just ask again :)
Show the output of:
ping 127.0.0.1 -c1
rbfeeder -v
Maybe there is some library version issue in regards to internet protocols.
But not sure what the exact problem is.
May be some files got corrupted during install of rbfeeder.
Purge and reistall rbfeeder.
NOTE: You must copy and save your key in a text file on your desktop/Laptop before purging.
sudo apt-get purge rbfeeder
sudo reboot
sudo apt-get install rbfeeder
After the apt-get install command, you may get "certificate not authenticated" warning. Ignore it by pressing y key then Enter key
When installation of rbfeeder is completed, do this:
# Restart and check status
# Is it working OK now?
#Replace the new key in this file by the key you have saved
sudo nano /etc/rbfeeder.ini
# Restart rbfeeder and check status
beeyev
wiedehopf sorry.
-rw-r--r-- 1 root root 124 May 25 20:29 /etc/rbfeeder.ini
[client]
network_mode=true
[network]
mode=beast
external_port=30005
ping 127.0.0.1 -c1
PING 127.0.0.1 (127.0.0.1) 56(84) bytes of data.
64 bytes from 127.0.0.1: icmp_seq=1 ttl=64 time=0.125 ms
--- 127.0.0.1 ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 0.125/0.125/0.125/0.000 ms
rbfeeder -v
[2019-05-25 23:51:19]  Compiled with arch=raspberry
RBFeeder v0.2.19 (build 20190226175114)
nc -zv 127.0.0.1 30005
localhost [127.0.0.1] 30005 (?) open
abcd567, reinstalling does not help at all, i tried several times different ways.
