Generating a Report
Started by spotter70, July 10, 2007, 08:31:20 PM
0 Members and 10 Guests are viewing this topic.
spotter70
When i generate a report of todays activities and wish to send them to myself as an Email it does not turn up in my email box or spam for that matter.
Can i send them, to myself ??
if not what is the function for on the reporter tab??
regards
spotter70
Yes, you can send it to yourself. Check your firewall is not blocking the software as thats the likely cause of it not sending.
spotter70
I have switched off the firewall and still cannot recieve
regards
spotter70
When you click send, what does the information box say in the corner?
spotter70
it says sending report but it never arrives.
i type my email address as normal the rport is generated below but it is not recieved.
regards
spotter70
prbflight
I'm having the exact same problem and it's driving me nuts!  I've checked my firewalls etc but can't find the cause of the blocking.  I can access the Network and Airliners.net form inside the RadarBox software.  I can't email any alerts or reports.  I get the following message all the time...
'Could not connect to SMPT server to send auto-report'
Paul
spotter70
at the moment i am writing down what i have verified overhead close to my home its annoying that i cannot get the email print it off so that i can log the entries into my database program
regards
spotter70
DaveG
just checked to see if reporting emails worked for me, and the answer is Nope..
Have a question:  What account does the email get sent by?  Is it a AirNav email account?  as if its not I cant see how it would work as without mail server setting and login details it would have no post office to send by.
Cornwall, UK
Ok we will look into this as well. Bear with us please. In the meantime you can save the log or regarding alert, you can save it to the alert box and you can copy that.
Its sent through our servers. It may be a server issue as it was working before.
paagats
#9
Hi all
Peter here in Sydney AU, I have the same problem but I save it to a file then e-mail to my local spotters group.
Not happy with the report generated as it comes out all over the place; I thought it would be a mirror image of MyLog.
Also, not all MyLog entries are appearing on the generated report. MyLog had 212 entries but only about 170 records appeared on the report. This happens every day.
Quote from: AirNav Support on July 10, 2007, 09:40:13 PM
Haven't had any success sending an email report to myself.  I've tried 2 different email addresses and although RB says sending mail in the status bar at the bottom, nothing appears in my email inbox.
I'm using Mozilla Thunderbird as the default mail client and I've also tried sending/receiving to a Google Mail Account.
