Author Topic: Flightstick Not Working on Radarbox V 6.02.003 - HELP!  (Read 18339 times)
wxwarn
« on: June 16, 2019, 04:25:29 PM »
I installed the flightstick drivers, plugged in the stick, fired up my Radarbox V 6.02.003 app but the it does not detect the hardware. I rebooted and did the process again but no hardware detected. I DO have the older Radarbox, black box, and it works fine, Can anyone help!
Re: Flightstick Not Working on Radarbox V 6.02.003 - HELP!
« Reply #1 on: June 16, 2019, 04:46:34 PM »
Try installing the Zadig drivers https://zadig.akeo.ie/
wxwarn
« Reply #2 on: June 16, 2019, 05:26:39 PM »
Thanks - tried loading drivers but no-go. RB 6 did not detect any hardware. HOPEFULLY AIRNAV SUPPORT CAN JUMP IN.
« Reply #3 on: June 16, 2019, 05:30:57 PM »
Did you see the stick on Zadig.
Do you see the stick in Windows Control Panel/Devices and Printers/Unspecified as RTL2838UHIDIR
Only other thing I can suggest is to try running as Administrator
Support will not see the thread, email them
« Last Edit: June 16, 2019, 06:02:27 PM by Runway 31 »
  • CYYZ - Toronto
« Reply #4 on: June 17, 2019, 11:32:23 PM »
(1) Which version of Windows are you using, 7 or 8 or 10?
(2) Please see this thread which describes step by step method to properly install driver Zadig.
Is My DVB-T RTL SDR Dongle Healthy?
« Last Edit: June 17, 2019, 11:34:15 PM by abcd567 »
wxwarn
« Reply #5 on: June 18, 2019, 02:12:04 PM »
I am using Windows 10-Pro. Will try your steps - thanks!
wxwarn
« Reply #6 on: June 18, 2019, 05:27:42 PM »
I tried the Zadig driver process but that still did not work. Thanks for the help but will probably have to return the flightstick for a refund since Airnav Support has not gotten back with me on my latest email requests to them!
« Reply #7 on: June 18, 2019, 06:04:02 PM »
Give me the ticket ID of the automatic responses and I will get them to contact you, also please pass me your email address to allow them to reply to you
wxwarn
« Reply #8 on: June 18, 2019, 06:15:56 PM »
Thanks but decided to return to amazon for a full refund - will post a comment for users NOT to buy flightstick since Airnav does not have quality software that works.
« Reply #9 on: June 18, 2019, 06:30:29 PM »
Deleted your last meassage on a new thread, dont start a new thread every time use exiasting threads
wiedehopf
« Reply #10 on: June 18, 2019, 06:30:47 PM »
You can use it with different software.
Quite a few possibilities.
Michel
« Reply #11 on: June 18, 2019, 06:34:42 PM »
Mine didn't work either the first time using it, and couldn't figure out what the problem was. What I did was de-install the flightstick, and re-install it again. Don't know what, but apparently something went wrong when installing the stick the first time.
« Reply #12 on: June 18, 2019, 06:48:06 PM »
Support advise they have not received any emails from you as indicated by you not being able to produce ticket ID's
If you could provide your email they can contact you
« Last Edit: June 18, 2019, 07:21:42 PM by Runway 31 »
wxwarn
« Reply #13 on: June 18, 2019, 07:23:21 PM »
I replied using my new email address. Support did reply to new email once but after I asked them multiple questions, I have not receive any replies from them. I am sorry but I should not have to work so hard to get a product to work! Airnav should have an out-of-the-box solution without all these hoops and others trying to help.
« Reply #14 on: June 18, 2019, 07:36:05 PM »
It does work out of the box for the vast majority of users without any issues.  Give me your ticket ID and I will have them contact you.  I would suggest that they have not received your follow up email.
« Last Edit: June 18, 2019, 07:40:08 PM by Runway 31 »
