Author Topic: Issues with Flightstick on Airnav RB6 software  (Read 11089 times)
wxwarn
« on: June 24, 2019, 04:57:16 PM »
WOW! After MANY posts and tries using AIRNAVS Flightstick, I return it for a refund from Amazon. After purchasing FLIGHTAWARES (flightaware.com) flightstick and installing on my current Windows 10 PC, IT WORKS OUT OF THE BOX using the same Airnav's Radarbox software V6.02.003!!! I have the legacy Radarbox black box which worked OK but FLIGHTAWARES product surpasses Airnav's product and works first time!!
I am getting 20-30 percent more received planes now.
Don't try Airnav flightstick, go to Flightaware!!
« Last Edit: July 03, 2019, 09:47:41 AM by AirNav Support »
wiedehopf
The green AirNav Stick can provide good performance.
If you have strong interfering signals the AirNav Stick can often provide better performance than the Pro Stick Plus.
(signal path is different, SAW filter comes before the LNA on the Airnav Stick)
Seems QC is not quite up to par and it apparently gets a bit hot.
But the price point is very aggressive and i'm sure you could have gotten a new one if you bought directly from them.
(and you got a refund which suggests you could've also gotten a replacement)
Maybe there is also a driver problem for Windows 10.
But i'm surprised the Flightaware Stick would work while the Airnav Stick wouldn't.
It should be exactly the same driver.
It works fine with the default rtl-sdr drivers on a Raspberry Pi.
It works fine with the Airnav drivers in the vast majority of cases although some users appear to have issues with it for some reason
  • CYYZ - Toronto
FlightStick works ok for me,both in Windows and RPi.
Aerotower
Airnav FlightStick works fine with windows!
But for some guys how don't know what they are doing.......
sylvantino
Re: Issues with Flightstick on Airnav RB6 software
« Reply #5 on: August 15, 2019, 05:09:50 AM »
I am pleased for the minority of people who are using the flight stick and it works right out the box, because you are the minority!
And I will tell you something else too. The latest update from windows has stopped the latest airnav drivers from being installed and used. This is why so many of us are coming here asking for help from the developer.  This latest update stops the driver from working. so depending on how many years old this driver is, there is going to be a lot of angry people, if there comes a need to reinstall the driver..its this reason why hardware: disconnected sits in red.
« Reply #6 on: August 15, 2019, 07:58:33 AM »
They are not the minority otherwise we would be flooded with messages here on the forum and support, Anyhow we have responded to your ticket, hopefully that gets you up and running.
« Reply #7 on: August 15, 2019, 08:55:57 AM »
It is the Windows update that is the problem and it is not only Radarbox that gets affected it is most applications that use specific drivers.  A windows update quite often replaces the specific drivers with their own and that is what causes the issue, Microsoft thinking they no what is best for you.
All that is required is for the Airnav drivers to be re-installed and all will be well again
« Last Edit: August 15, 2019, 08:58:43 AM by Runway 31 »
« Reply #8 on: August 16, 2019, 02:26:35 PM »
Just to update sylvantino driver issue has been resolved.
