My feed stays connected but the plane data stops
Started by wa2tqi, June 29, 2019, 03:08:47 PM
wa2tqi
I have one Pi that supplies the raw data feed to several feeds. All of the other feeds except Radarbox are receiving plane data just fine. On my second Pi I have RBFEEDER running. When I start up the RB feed all is well. Planes appear on my local feed window. After a rather short amount of time the connection to RB remains OK and feed status turns to yellow. In order to get the feed running again I have to rerun 'rbfeeder status' on the PI sending data up to radarbox. Any ideas what could be causing this???
Bill
elTrauko
I had the same problem, update everything fix ir.
Yellow shows that you are online but you are not picking up any aircraft so are not sening any data.  If its not that I suggest that you contact support and ask them.
