rbfeeder unable to locate error
Started by jstutman, July 04, 2019, 02:30:13 AM
jstutman
Following these instructions.
radarbox24.com/raspberry-pi/guide
after I run the command
sudo bash -c "$(wget -O - rb24/inst_rbfeeder.sh)"
I get the following error:
E: Unable to locate package rbfeeder
imgur./a/pRCwUpX
*I apparently have to edit all of the url's cause it thinks I am spam.
jstutman
#2
sudo apt-get update
sudo apt-get install rbfeeder
After last command it may ask  "...not authenticated. Install without authentication?".
Press y key (for yes) and then press Enter key.
When installtion completes, gives these two commands
jstutman
#3
Thanks. I had to install apt-transport-https first but then following your additional commands got me all taken care of.
Next issue is trying to install MLAT as the station says it is not configured.
https://www.radarbox24.com/stations/EXTRPI001115
This is the error I get when trying to install the mlay-client
https://imgur.com/a/floaqtf
also MLAT is configured for piaware.
https://flightaware.com/adsb/stats/user/jstutman#stats-41947
wiedehopf
Show
cat /etc/os-release | grep -i pretty
Probably you are on an older system.
So you can probably get the current piaware sd-card image and fix it like that.
Or try:
sudo apt update
sudo apt dist-upgrade
That may fix the problem.
Or you can compile the mlat-client from source:
https://github.com/mutability/mlat-client
Quote from: jstutman on July 04, 2019, 04:42:48 AM
I got exactly same problem on Raspbian Buster. Seems you are also using Raspbian Buster. Here is the solution I posted yesterday:
https://www.airnavsystems.com/forum/index.php?topic=101771.msg407051#msg407051
wiedehopf
Read the message more closely, his python version is 3.4, but mlat-client needs >= 3.5
Your python version is 3.7 but mlat client needs < 3.6
So in essence the precompiled version needs version 3.5
Basically you need to either run Raspbian Stretch or compile mlat-client yourself.
