Sight Lines
Started by Paulc, June 17, 2008, 08:40:48 PM
Paulc
How can these be turned off ? Using the clear button in preferences does not seem to do much as they come back almost immediately.
If you mean the polar diagram, use Map | Polar Diagram to switch it off - or you can use the button on the main menu bar just up and to the left of the Destination label - looks like a yellow star on a black background.
All the clear button does is clear it so you can start again.  As soon as an aircraft is detected, a new polar diagram will start to build up.
You might be talking about the vector lines which are infront of the aircraft. To turn them off go to Prefences and untick 'Draw patch vector'
Paulc
#3
Many thanks - all gone - must have pressed it during a bit of 'tinkering'
One other thing I have noticed - the altitude column is not quite wide enough to show all the figures? when it is on the rhs of the table - display ok if another item selected
Paulc,
Sometimes the columns in the aircraft list table can be truncated if you are only showing a few columns.  If you tick the "Squawk" box in preferences - Grid Visible Cloumns, then you will have the full width altitude column and the squawk.
Paulc
Allocator,
thanks for that - I have added a tick to another box after the altitude and both now display in full.
Having only had the box for a few days it is an impressive bit of kit, even a friend of mine who has an sbs box was impressed and that was before I had made a few changes. The real plus from my point of view is its size which makes it much more portable. Am really impressed with how easy it was to download and install outlines
