Filters
Started by Spaice, June 18, 2008, 06:41:49 AM
Spaice
When using the filters, is it possible to select not equal to or not like to filter out unwanted aircraft or airlines, for example you might want to filter out all Easyjet aircraft and display everything else.  Or have I missed something?
Spaice,
Just use the <> (not equal to) in the Quick Filter, like:
FlightID <> EZY*
Spaice
Thanks Allocator, should have worked that one out really, for some reason I was thinking !=
mt007
Guys,
i need your help wiht this situation.
I have a local traffic, like helicopters and airplanes and they have contact with portuguese ATC so they appear in ATC radar screen, wright? ok.
So why dont appear on my RD screen?
I have helicopters passing for my house and nohting i see in RB.
Any idea?
Thx.
Hi MT
All air traffic will appear on "proper" ATC screens because "proper" ATC has its own radar to detect it! RB doesn't detect this at all. Most light aircraft and helicopters are like this, so they don't appear on RB.
Aircraft with "Mode S" have equipment to "squawk" a code along with the aircraft's altitude, so that ATC can tell which blip is which, and that will also be picked up by RB, so that the aircraft will appear in our lists. Many regional jets and turboprops, and many military aircraft have this
Only aircraft with extra ADS-B equipment broadcast their position, heading etc - RB picks that up so that they can be placed on the map.
Hope that explains it!
mt007
Hy Rod,
But this aircrafts and helicopters have squawk codes.
Dont we can see this aircrafts in RB?
And is not possibel to Airnav make possible we can see all aircrafts?
Thx.
Deadcalm
Because squawk codes are issued by ATC for code callsign conversion of Secondary Surveillance Radar.  SSR is ONLY available to ATC, and not us.  We do not receive SSR with Radarbox - this rides on the back of primary radar and interrogates aircraft.  None of us could afford radar, for a start, let alone have access to all that it entails.  Radarbox intercepts ADS-B signals from aircraft, an entirlely different concept, an entirely different signal broadcast in an entirely different way, and is not compulsory equipment - which is why many don't have it.
DC
MT - just transmitting a Squawk code doesn't tell anybody the aircraft's position, only its identity and its altitude. RB puts those aircraft in the list, working out the aircraft type by matching the Mode S code in the databases.
RadarBox can't pick up position information from aircraft just fitted with Mode S because it's not being transmitted - only aircraft with ADS-B do that, so while they appear in the list, they can't appear on the map, because only "proper" ATC, with its radar,  knows where they are! (actually, with any luck, the pilots do too! :-))
mt007
Ok, thx guys.
Regards.
Hope all that made sense, MT!
AS DC says, ADS-B isn't compulsory, yet. There are moves to extend its use - it not only helps ATC ("ADS-B Out"), but other aircraft can also pick up the signals to use for collision avoidance ("ADS-B In").
Trouble is, it's apparently pretty expensive, but even so, more and more aircraft should be getting it, making RadarBox even more interesting as time goes by.
mt007
I hope so, Rod.
Thx.
Spaice
I have tried to use the quickfilter to filter out all Easyjet aircraft, however I get very strange results.  I selected Airline <> EASYJET and click on the Filter button.  Myflights then increases from 47 to 505 with no effect on filtering out the Easyjet aircraft, I then select Show All and myflight returns to displaying 47.  Has anybody else experianced similar issues?  or is there a workaround od some kind.
Spaice,
If you use this, it works OK
FlightID <> EZY*
Must be a bug regarding Airline <> EASYJET
Spaice
Allocator,
I rtied your idea, but for some reason I get the same problem, it does look like some kind bug though.  I even tried putting the same filter selection for the network to match that of the myflights and had the same aircraft count on both the myflight and network tabs.
Ah.....yes, I see what you mean.  Same problem here - gets rid of the Easyjet aircraft but puts everything into the MyFlights list.
Must be a bug!
