Help getting adsbexchange working again
Started by fritz614, January 23, 2020, 12:00:30 AM
fritz614
I have a Pi3+ with a FA USB dongle running adsbexchange.  I added RadarBox today, and now I can not see my feed from my original install, but can see RadarBox.  I am sure I entered something wrong somewhere as I am not very good at Pi language or the programs themselves.
I think I need to configure it so that RadarBox does not start it own dump1090.
any help would be great!
#1
Please post output of following command (remove feeder key before posting
cat /etc/rbfeeder.ini
For your reference, this is output on my RPi
The setting which will prevent built-in dump1090 to start is
network_mode=true
With above setting, you have to have other settings shown in red to pull data from your installed dump1090-fa or dump1090-mutability
Quote
[client]
network_mode=true
key=xxxxxxxxxxxxxxxxxxxxxx
sn=EXTRPI00xxxx
lat=xx.xxxx
lon=yy.yyyy
alt=zzz
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
