Author Topic: database update  (Read 15954 times)
jacobite
database update
« on: January 23, 2020, 09:28:39 AM »
Hi all, I have recently had to set up my micro radar box as my laptop died on me. RadarBox is up and running but it will not update the database, help please
Ian (jacobite)
Re: database update
« Reply #1 on: January 23, 2020, 10:47:03 AM »
The update is working Ian so can only presume that it is going elsewhere on your computer, a previous installation.  Did you install to program files ?
jacobite
Re: database update
« Reply #2 on: January 23, 2020, 12:31:18 PM »
Hi Alan, it is a completely new install as my laptop gave up on me and I decided to purchase a pc instead, so I have had to start all over again
Re: database update
« Reply #3 on: January 23, 2020, 12:51:17 PM »
Do you have the software set to sharing data in Preferences
Use windows search to look for NavData.db3 it should be in your Radarbox/Data folder what date does it have and if you updated today you should also have NavData.db3.20200123 as well
jacobite
Re: database update
« Reply #4 on: January 23, 2020, 01:23:18 PM »
NavData.db3 does not show anywhere Alan. I have checked sharing data in preferences and I cannot get that to work either.
Re: database update
« Reply #5 on: January 23, 2020, 01:30:53 PM »
If you didn't have a Navdata.db3 file you would not be getting any information of the aircraft you are picking up so you must have the file somewhere.  The Navdata populates the aircraft data
If search is not finding it look for it manually in your Radarbox/Data folder
jacobite
Re: database update
« Reply #6 on: January 23, 2020, 02:26:45 PM »
I think I am going to have to uninstall ANRB and start again as I cannot find the data folder anywhere.
Re: database update
« Reply #7 on: January 23, 2020, 02:57:08 PM »
When you open up the Radarbox folder it has Color, Data, Drivers,Filter Help and Manuael etc folders in that order from the top of the page
jacobite
Re: database update
« Reply #8 on: January 23, 2020, 04:24:27 PM »
Yes Alan that is all correct.
Re: database update
« Reply #9 on: January 23, 2020, 05:00:05 PM »
Got me confused Ian as you previously said you couldn't find the data folder
jacobite
Re: database update
« Reply #10 on: January 23, 2020, 06:20:26 PM »
Yes Alan, that is correct I had to reinstall ANRB to get the data folder back but it still does not work as it shows that it is CORRUPT. .L020.DAT 09/02/2004 Or am I looking at the wrong DAT file
« Last Edit: January 23, 2020, 06:31:56 PM by jacobite »
Re: database update
« Reply #11 on: January 23, 2020, 06:53:13 PM »
Its not a DAT file you are looking for,it is NavData.db3 you are looking for, see attached
jacobite
Re: database update
« Reply #12 on: January 24, 2020, 09:05:44 AM »
Alan, after finding the NavData.db3 it still does not update the database. I am wondering if it has anything to do with anti virus software.
Re: database update
« Reply #13 on: January 24, 2020, 09:24:53 AM »
Is the NavData in your data folder as expected.  Also did you install to c:\Airnav or similar or to program files.  I don't think the anti virus should be an issue
When you try to update are you getting anything on the Update Progress Log per attached
« Last Edit: January 24, 2020, 09:27:28 AM by Runway 31 »
jacobite
Re: database update
« Reply #14 on: January 24, 2020, 10:31:25 AM »
No Alan I did not install to c:Airnav it went to program files, I will see if I can move it.
