Author Topic: dump978-rb Failure Due to Missing SoapySDR [S O L V E D]  (Read 8979 times)
  • CYYZ - Toronto
« on: February 18, 2020, 04:06:52 AM »
Today on Armbian Buster, I installed rbfeeder and during installation said "yes" when was asked "do you want to install dump978-rb?".
After installation I found dump978-rb has failed to run:
Code: [Select]
$ sudo systemctl stsatus dump978-rb
ExecStart=/usr/share/dump978-rb/start-dump978-rb (code=exited, status=2)
Checked by directly starting dump978-rb
Code: [Select]
$ /usr/bin/dump978-rb --sdr driver=rtlsdr,serial=00000401 --sdr-auto-gain --format CS8 --raw-port 30978 --json-port 28380
Configuration error: No matching SoapySDR device found (cause:SoapySDR::Device::make() no match)
Solved by installing missing soapysdr package, and then restarting dump978-rb
Code: [Select]
$ sudo apt install soapysdr-module-rtlsdr
$ sudo systemctl restart dump978-rb
Checked Status, working OK now.
Code: [Select]
$ sudo systemctl status dump978-rb
● dump978-rb.service - dump978 ADS-B UAT receiver
   Loaded: loaded (/lib/systemd/system/dump978-rb.service; enabled; vendor preset: enabled)
   Active: active (running) since Tue 2020-02-18 02:14:25 UTC; 1s ago
     Docs: https://www.radarbox.com
 Main PID: 9885 (dump978-rb)
    Tasks: 4 (limit: 2068)
   Memory: 7.8M
   CGroup: /system.slice/dump978-rb.service
           └─9885 /usr/bin/dump978-rb --sdr driver=rtlsdr,serial=00000401 --sdr-auto-gain --format CS8 --raw-po
Feb 18 02:14:25 orangepipc dump978-rb[9885]: Found Rafael Micro R820T tuner
Feb 18 02:14:25 orangepipc dump978-rb[9885]: Reattached kernel driver
Feb 18 02:14:26 orangepipc dump978-rb[9885]: Detached kernel driver
Feb 18 02:14:26 orangepipc dump978-rb[9885]: Found Rafael Micro R820T tuner
Feb 18 02:14:26 orangepipc dump978-rb[9885]: Exact sample rate is: 2083333.135571 Hz
Feb 18 02:14:26 orangepipc dump978-rb[9885]: [R82XX] PLL not locked!
Feb 18 02:14:26 orangepipc dump978-rb[9885]: SoapySDR: using automatic gain
Feb 18 02:14:26 orangepipc dump978-rb[9885]: SoapySDR: using stream setting buffsize=262144
Feb 18 02:14:26 orangepipc dump978-rb[9885]: Allocating 15 zero-copy buffers
Feb 18 02:14:26 orangepipc dump978-rb[9885]: Detected Kernel usbfs mmap() bug, falling back to buffers in users
« Last Edit: February 18, 2020, 04:11:33 AM by abcd567 »
  • CYYZ - Toronto
Re: dump978-rb Failure Due to Missing SoapySDR [S O L V E D]
« Reply #1 on: February 19, 2020, 01:25:59 AM »
Sent email today to Jonis Ceara and Andre Brandao of AirNav, informing about this bug & link to above post. Hopefully it will be fixed soon.
