Need helpt to get my RadarBox Feed running
Started by FlyingLord, February 22, 2020, 08:54:00 AM
abcd567
Very strange.
Several persons complained that on Buster when the give command "sudo apt-get install mlat-client, the get responce "not found".
Today morning I tested and found I cannot install mlat-client on Buster by above command.
Possibly by the time you tried, Radarbox24 have fixed the issue. I will again try tonight and see.
FlyingLord
OK. Thank you very much for the assistance. I'm happy for the moment except the range. :D
abcd567
Quote from: FlyingLord on February 22, 2020, 08:14:06 PM
Which antenna are you using? Is it installed indoor or outdoor?
Range mainly depends on:
Antenna location (indoor or outdoor)
Antenna height
Antenna type
Length and quality of coax cable from antenna to dvbt
#18
The topograhy of your surroundings will also impact on your range, ie high buildings, trees, mountains etc all in ralation to your antenna location.  Also whether you are in a valley, located up a mountain etc
