Author Topic: Installing RBFEED is not working on Pi  (Read 10324 times)
GER_EDDM
« on: April 22, 2020, 12:08:40 PM »
I tried to install the RBFeeder on my Pi.
I used the instruction https://www.radarbox.com/raspberry-pi/guide
Unfortunately I didn't work. I can not unterstand what's going on wrong.
Can anyone help me?
The configuration files is empty, and when I type the other commands, like
there is always the answer:
Failed to restart rbfeeder.service: Unit rbfeeder.service failed to load: No such file or directory.
The protocol is attached.
Thank you soo much for your help!
  • CYYZ - Toronto
Re: Installing RBFEED is not working on Pi
« Reply #1 on: April 23, 2020, 05:38:43 AM »
Does your Pi has Raspbnian JESSIE? If yes, that is too old, and there may be compatibilty problem. Better install Raspbian Buster.
If you are not sure, check by this command
lsb_release -sc
