No data and offline
Started by riderz49, April 28, 2020, 04:02:00 PM
riderz49
1. RB was working, but it's gone offline and, duh, no data. Can't figure out how to fix. I also have SkyAware and FlightRadar24 installed. Both are working.
2. When RB was working, my filter settings and map options were not retained. Is there some trick to retaining them?
What is your sharer ID and what receiver type do you have I presume a Pi
Regarding the filters I believe you require to set these each time but I believe the map you have set stays, maybe wrong on that though, maybe support can advise
riderz49
ID 3662985
FlightAware receiver
I don't recognise that station ID its usually PGNRB**** for Radarbox receivers, EXTRPI***** for Pi's, EXTSHA**** for other receivers etc
Are you using the sharing software?
riderz49
Ah a Pi, hopefully abcd567 will notice your post, I know nothing about Pi's
anorak
Hi, do you know what software you are running your Pi on?
Dave.
Dave. Exmoor, North Devon.
riderz49
Please post output of following commands:
apt policy rbfeeder
Please also post output of following command
(In the post, replace actual value of key by xxxx )
cat /etc/rbfeeder.ini
riderz49
I copied the output into attached txt file. (When I tried to send reply with out pasted directly into message, it was bounced as "spam."
Thanks in advance for your help.
RBFeeder is installed, configured ok, but not working. Seems some file got corrupt.
Reinstall it, but first copy-paste key from file /etc/rbfeeder.ini in Notepad on your Windows/Mac computer.
Reinstall command:
sudo apt-get purge rbfeeder
sudo apt-get update
sudo apt-get install rbfeeder
sudo rbfeeder --setkey xxxxxx --no-start
## In above command replace xxxxx by your actual key
riderz49
That did the trick.
Thank you---again, abcd567
cosmefulanito
Hi, I have a radarbox unit PGANRB114140 and for a few days I have not had access to real time network flights from the 6.02.003 software and since yesterday Its not sharing data with radarbox24 either.
I see that you are showing offline on Radarbox.com for 20hours.  While you mention network flight, are you getting flight locally on MyFlights on your V6 software.
cosmefulanito
Yes I have flight locally and the sharing option active.
