Author Topic: How to eliminate "Can't connect to 978 source" messages?  (Read 11272 times)
vantage
« on: July 03, 2020, 09:03:41 PM »
I've got my radarbox RPi feeder working running fine but I keep getting these messages in /var/log/rbfeeder.log so the file keeps growing:
[2020-07-03 21:43:11]  Can't connect to 978 source (127.0.0.1:28380). Waiting 5 second...
[2020-07-03 21:43:16]  Can't connect to 978 source (127.0.0.1:28380). Waiting 5 second...
[2020-07-03 21:43:21]  Can't connect to 978 source (127.0.0.1:28380). Waiting 5 second...
It's probably because I built the SD card image with the 978 software thinking I might add the dongle in the future but it's not there now. How do I stop those messages?
TIA
  • CYYZ - Toronto
Re: How to eliminate "Can't connect to 978 source" messages?
« Reply #1 on: July 03, 2020, 10:43:40 PM »
@vantage:
(1) Open file rbfeeder.ini
Code: [Select]
sudo nano /etc/rbfeeder.ini
(2) Scroll down till you see following:
[dump978]
dump978_enabled=true
Change true to false so it becomes:
[dump978]
dump978_enabled=false
(3) Save file (Ctrl+O) and close (Ctrl+x)
(4) Restart rbfeeder
Code: [Select]
(5) Above is enough to stop irritating warning "Can't connect to 978 source".
However if you are not running dump978-rb, better to disable it, otherwise it unnecessarily keeps running in background, genersting its own log "unable to find the dongle". To stop it do following:
Code: [Select]
sudo systemctl stop dump978-rb
sudo systemctl disable dump978-rb
(6) If anytime you get a second dongle for 978, you can enable and start dump978-rb by following commands:
Code: [Select]
sudo systemctl enable dump978-rb
sudo systemctl start dump978-rb
vantage
« Reply #2 on: July 04, 2020, 02:09:12 AM »
That worked perfectly. The only hiccup was it killed mlat-client too. I cold-started the Pi and everything is running now. The tip on re-enabling 978 is appreciated.
Thanks again.
  • CYYZ - Toronto
« Reply #3 on: July 04, 2020, 02:34:22 AM »
What I understand is that:
(1) When you disabled dump978, mlat also stopped.
(2) After that when you cold started Pi, mlat got restored.
Did I get you right?
vantage
« Reply #4 on: July 04, 2020, 05:15:17 AM »
I don't know if it was after the 'sudo systemctl restart rbfeeder', 'stop' or the 'disable' but one of them did it. I would have to assume it was the stop. After I was done with the steps you outlined I ran 'top' and mlat-client was missing. So I cold-started the Pi and rbfeeder and mlat-client were both running normally.
  • CYYZ - Toronto
« Reply #5 on: July 04, 2020, 05:32:14 AM »
Great! Glad that your system is finally runnung normally. Does not matter what happened during fixing the trouble, it was only a temporary thing.
