Author Topic: Support  (Read 13860 times)
SkyPi
Support
« on: July 04, 2020, 11:00:11 AM »
Does anyone know how long it should take Support to reply to emails? I've been waiting a week.
I want to get my feeder position on the map moved, as it's miles out.
I'd also like to upgrade my account, using my sharing key. I can't find anywhere to do so on the site. Does Support have to do it?
TIA
EXTRPI010157
« Last Edit: July 04, 2020, 11:16:18 AM by SkyPi »
Re: Support
« Reply #1 on: July 04, 2020, 01:50:59 PM »
SkyPi
Support aim to reply within 24 hours, did you get an auto reply, if not they have not received your email
Regarding your position on the map if you bring up your station you will see next to your location Cranage on the grid top left Edit, click on it and enter your exact location lat/lon
Your account should upgrade automatically to Business but if it has not for some reason advise support [email protected] of your station EXTRPI010157 number along with your email address used to log into RB and ask them to link your receiver to your account.
« Last Edit: July 04, 2020, 01:57:45 PM by Runway 31 »
Re: Support
« Reply #2 on: July 04, 2020, 02:07:31 PM »
We have no email from your gmail account, please send again and check you get a ticket id which confirms we have got it.
SkyPi
Re: Support
« Reply #3 on: July 04, 2020, 04:14:55 PM »
SkyPi
Thanks for the reply.
Do you mean this page?
https://www.radarbox.com/stations/EXTRPI010157
I don't see anything that I can edit.
SkyPi
Re: Support
« Reply #4 on: July 04, 2020, 04:16:50 PM »
I sent from a different email account. Just received your reply a few minutes ago.
Re: Support
« Reply #5 on: July 04, 2020, 04:24:09 PM »
Sky Pi
To the right of Croydon it states Edit, click on it and it brings up a window Please insert your station location.  Enter your Latitude and Longitude, click Exact Location then Preview and Save I think it is
SkyPi
Re: Support
« Reply #6 on: July 04, 2020, 04:48:24 PM »
Sorry, but I don't seem to have it.
Screenshot attached.
Re: Support
« Reply #7 on: July 04, 2020, 05:06:10 PM »
I can only presume that you are not logged in, it should be like the attached
SkyPi
Re: Support
« Reply #8 on: July 04, 2020, 05:11:54 PM »
I've logged out and back in again, but no change.
Re: Support
« Reply #9 on: July 04, 2020, 05:25:17 PM »
No idea, they all show with Edit for me, another thing for you to ask Support, maybe its because the receiver is not linked to your account yet
SkyPi
Re: Support
« Reply #10 on: July 04, 2020, 05:48:11 PM »
Also tried both Opera and Firefox, but no change.
I'll get onto support, thanks.
  • CYYZ - Toronto
Re: Support
« Reply #11 on: July 05, 2020, 04:39:18 AM »
@SkyPi:
Most likely you have claimed/linked your station using one email account, but when you visit web map, you login using another email.
Another possible cause may be that to visit web map, you are using station number which does not belong to you.
Please do this:
(1) Open file rbfeeder.ini to edit
Code: [Select]
sudo nano /etc/rbfeeder.ini
(2) In opened file check following line:
sn=EXTRPIxxxxxx
Is it EXTRPI010157 ?
If yes, go to step (3)
If no, then you have been visiting web map of a wrong site. Visit web map with station number in the file rbfeeder.ini
(3) In the file opened, add three lines shown in red below. Replace
xx.xxxx by your actual latitude value
yy.yyyy by your actual longitude value
zzz by your actual altitude value (meters above sea level)
Quote
[client]
network_mode=true
key=xxxxxxxxxxxxxx
sn=EXTRPI010157
lat=xx.xxxx
lon=yy.yyyy
alt=zzz
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
[dump978]
#dump978_enabled=true
(4) Save file (Ctrl+O) and close it (Ctrl+x)
(5) Restart rbfeeder
Code: [Select]
(6) Wait 10 minutes, then check your map
« Last Edit: July 05, 2020, 07:31:41 AM by abcd567 »
SkyPi
Re: Support
« Reply #12 on: July 05, 2020, 10:12:03 AM »
Thanks,
I've updated the config file with lat/long etc, but the map hasn't changed.
It may well be the account settings, so I've emailed support.
Re: Support
« Reply #13 on: July 05, 2020, 01:33:52 PM »
In your Profile on RB for current plan are you Business?  If not it is still to be linked
SkyPi
Re: Support
« Reply #14 on: July 05, 2020, 01:57:28 PM »
No, not upgraded yet.
Still waiting for a reply from support on that, and which email address is linked to it.
