Author Topic: radarbox drivers  (Read 8513 times)
PAULW
radarbox drivers
« on: October 02, 2020, 07:44:49 PM »
Dear All,
Sorry if I posted on the wrong forum page.
I am trying to install radar box onto a new PC, I haven't used this radarbox for about 3 years,
Installing the main application is fine but I am having real trouble where to put the drivers once I have downloaded them.
I have used the support email and they have been great. I am just really bad with my understanding of where the drivers go. If anyone can provide a step by step process for me (bearing in mind I am pretty stupid with computors) it would be very much appreciated
Re: radarbox drivers
« Reply #1 on: October 02, 2020, 08:28:19 PM »
You can get the drivers from here http://www.airnavsystems.com/Download/ANRB/Drivers/ANRB-Drivers-20161222.zip
Note they are zipped and need to be unzipped into the Airnav Systems/Airnav Radarbox/Drivers folder
PAULW
« Reply #2 on: October 02, 2020, 08:36:48 PM »
Many thanks . I will try that.
Your response is very much appreciated
Brgds Paul
PAULW
« Reply #3 on: October 03, 2020, 01:01:26 PM »
I think I've gone wrong somewhere. Also no ability to unzip.Screenshot attached
Brgds Paul
PAULW
« Reply #4 on: October 03, 2020, 01:05:17 PM »
attached
    • Rod's RadarBox Downloads
« Reply #5 on: October 03, 2020, 03:28:17 PM »
Hi Paulw
I see from the screenshots that you are installing RadarBox in a Program Files folder. It is strongly recommended that you use a folder such as C:\Airnav or anywhere else outside Program Files or Program Files (x86), so I suggest that you uninstall your current RadarBox and install it again.
« Reply #6 on: October 03, 2020, 04:44:47 PM »
Paul
Download them drivers using the link sent previously, once downloaded click on the download and new window will open, you will see the Drivers, right click on them and another window will open with a list Click on Extract Files to a specified folder, click on Local Disk c and you should see the Airnav Systems folder and to the right of it is a box with a plus sign, click on it and you will see Airnav Radarbox, click on it and you will see drivers, click on it until Drivers with a plus sign in a box beside it, click on the box and its contents opens then click on OK and the drivers will extract to the drivers folder
As Rod stated you should have installed the V6 software away from Program Files to c:\Airnav
You would be better using the Windows snipping tool to take screen shots as not everyone has Open Office installed to open ODT files
« Last Edit: October 03, 2020, 04:47:20 PM by Runway 31 »
