Author Topic: MLAT - FR24+DUMP1090 to RadarBox24 FEEDER  (Read 10613 times)
MatheusMoraes
« on: October 09, 2020, 01:35:02 PM »
Guys help me!
I've a raspberry pi 3 A+ running a FR24 feed with dump1090 mutability. I recent installed RadarBox24 feeder with network mode off. It work for a while and MLAT was active and running. Some days later I got a issue, the rb24 was conflicting with fr24, so I turned rb24 network mode ON using the following:
sudo rbfeeder --set-network-mode on --set-network-host 192.168.0.101 --set-network-port 30005 --set-network-protocol raw --no-start
FR24 and RB24 are now working well since a while, but I notice that RB24 is no longer feeding MLAT even the option is ON:
[client]
network_mode=true
key=xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
sn=EXTRPI013363
[network]
mode=raw
external_port=30005
external_host=192.168.0.101
[mlat]
autostart_mlat=true
[dump978]
#dump978_enabled=true
Please is there a way to make MLAT work again????
Re: MLAT - FR24+DUMP1090 to RadarBox24 FEEDER
« Reply #1 on: October 09, 2020, 02:27:29 PM »
Matheus
I know nothing about Pi's but from this thread the poster had the same issue https://forum.radarbox24.com/index.php?topic=103851.0  and he was advised
Change true by false as shown below
[mlat]
autostart_mlat=true  false
Save file.
Restart rbfeeder
MatheusMoraes
« Reply #2 on: October 09, 2020, 02:45:28 PM »
Thanks Runway31. But actually the post you mentioned is trying to unninstall/remove RB MLAT. In my case I am looking for a way to MLAT to work. It used to work nice when configured network mode OFF. Since I changed to network mode ON the feeder is just getting ADS-B data. I'd like to know if there is some configuration about using RB with network ON that makes MLAT to work again.
« Reply #3 on: October 09, 2020, 03:03:28 PM »
Told you I didnt know anything regarding Pi's.  See https://forum.radarbox24.com/index.php?topic=101771.0  One of the later posts states
There are two things required to be done:
(1) Install mlat-client,
(2) Set your latitude, longitude and antenna elevation. Did you do it? If not it can be done in any one of the two ways:
(a) Add these in file /etc/rbfeeder.ini
OR
(b) Go to your RB24 map on internet and add it there.
Both the above methods are described in STEP-2 of this post:
https://forum.radarbox24.com/index.php?topic=101771.msg389571#msg389571
  • CYYZ - Toronto
« Reply #4 on: October 09, 2020, 09:29:55 PM »
To enable MLAT, you have to:
(1) Make sure in file /etc/rbfeeder.ini :
(a) under [client] add your latitude, longitude and elevation (meters above sea level) as follows
lat=xx.xxxx
lon=yy.yyyy
alt=zzz
(b) the line autostart_mlat is set to true, as shown below:
[mlat]
autostart_mlat=true
(2) Install mlat-client
Code: [Select]
sudo apt install mlat-client
sudo reboot
« Last Edit: October 09, 2020, 09:38:13 PM by abcd567 »
Dutchy
« Reply #5 on: November 26, 2020, 02:48:37 PM »
Hello all,
I am trying to install the Flat client. Read all posts here. This is my breeder.ini file:
[client]
network_mode=true
key=xxxxxxxxx
sn=EXTRPxxxxx
lat=52.509113
lon=6.110756
alt=20
sat_used=0
sat_visible=0
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
mlat_cmd=/usr/bin/python3.5 /usr/bin/mlat-client--results beast,listen,30104
[dump978]
Added --results beast,listen,30104 in my file as suggested.
When I run the command python _V it gives me
Python 2.7.16
So my guess is, that something is not right.
Does anyone has an idea?  If I have to upgrade my buster to 3.7 how to do it, as I read there is already a version 3.8
In my flightless I can see the green Meat, but I do not see a line that I am sync to any MLAT feeders
« Last Edit: November 26, 2020, 02:51:02 PM by Dutchy »
  • CYYZ - Toronto
« Reply #6 on: November 26, 2020, 09:58:24 PM »
(1) You can check if python3.7 is installed or not by following command
Code: [Select]
apt-cache policy python3.7
(2) What is output of this command
Code: [Select]
lsb_release -sc
If output is "stretch", the mlat setting will be
[mlat]
autostart_mlat=true
If output is "buster", the mlat setting will be
[mlat]
autostart_mlat=true
mlat_cmd=/usr/bin/python3.7 /usr/bin/mlat-client--results beast,listen,30104
Dutchy
« Reply #7 on: November 27, 2020, 12:18:03 PM »
Thank you for your answer
Here is the outcome:
pi@raspberrypi:~ $ apt-cache policy python3.7
python3.7:
  Installed: 3.7.3-2+deb10u2
  Candidate: 3.7.3-2+deb10u2
  Version table:
 *** 3.7.3-2+deb10u2 500
        500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
        100 /var/lib/dpkg/status
pi@raspberrypi:~ $ lsb_release -sc
buster
It says 3.7 but when I check the ini file it says 3.5
pi@raspberrypi:~ $  sudo nano /etc/rbfeeder.ini
  GNU nano 3.2                      /etc/rbfeeder.ini
[client]
network_mode=true
key=e0ace727a935e6873c793c60f5ddd3de
sn=EXTRPI001976
lat=52.509113
lon=6.110756
alt=20
sat_used=0
sat_visible=0
[network]
mode=beast
external_port=30005
[mlat]
autostart_mlat=true
[dump978]
  • CYYZ - Toronto
« Reply #8 on: November 27, 2020, 03:26:19 PM »
Hi Dutchy
The output of commands "lsb_release -sc" and "apt-cache policy python3.7" confirm that you have buster and python3.7, but in file /etc/rbfeeder.ini you have python3.5. This mismatch is causing mlat to fail.
Please edit file /etc/rbfeeder.ini and change 3.5 to 3.7 in following line:
After changing, save file, then restart rbfeeder
« Last Edit: November 27, 2020, 03:34:43 PM by abcd567 »
Dutchy
« Reply #9 on: November 27, 2020, 03:56:28 PM »
I did as you said, changed 3.5 in 3.7
Emptied my cache. Waited and Tried again.
Still I cannot see that I am synced to others.
Please advice
« Last Edit: November 27, 2020, 09:01:15 PM by Dutchy »
  • CYYZ - Toronto
« Reply #10 on: November 27, 2020, 07:11:34 PM »
1. Delete the screenshot you posted as it reveals you RB24 Key. Instead post another copy with your RB24 Key removed.
2. Your MLAT is not active. This is due to a typing error in config
This line in your config has NO SPACE between mlat-client  and --results:
It should be like this :
mlat_cmd=/usr/bin/python3.7  /usr/bin/mlat-client   --results beast,listen,30104
Please add required space as shown above and restart rbfeeder.
« Last Edit: November 27, 2020, 08:01:22 PM by abcd567 »
Dutchy
« Reply #11 on: November 28, 2020, 01:20:07 PM »
Thank you so much for your patience and help
Mlat is up and running smoothly..Wondeful
