Data Problem
Started by Phil-Robo, October 14, 2020, 11:48:35 AM
Phil-Robo
I have aircraft on my screen but it says no data in the box in the bottom left hand corner, is my data getting through or not.
I'm using a Pi 2, if it helps.
markr468
I think the problem is on their end, as mine looks similar but I still show aircraft like you do. I also checked some logs and everything looks fine.
sudo tail -f /var/log/rbfeeder.log
Phil-Robo
#2
Mark,
Thanks all seems to be fine now, i reinstalled everything.
I had aircraft on mine but no data was getting through, yours looks like data might not be getting through.
When all is working the lines should be green.
There was an outage at the Airnav end in the early hours, nothing wrong at your end
EXTRPI004730
I seem to be having the same trouble with connectivity; plane count is normal, RPI and peripherals fine, good LAN data, just not communicating well with RB24/Airnav server I guess. Been up and down. Hope they rectify the issue.
-G.
#5
Did you advise support there may be an issue
I note feeders are showing yellow for no data although aircraft are on screen
#6
Now fixed and the missing green time is to be restored
