Author Topic: RadarBox Legacy w/Win10 mouse issues  (Read 8975 times)
davidp124
« on: November 06, 2020, 12:56:36 AM »
Having a bit of an issue with mouse no longer highlighting selected flight on map when curser placed on a selected aircraft.  Currently using win10 with all updates and Legacy RadarBox 6.02.003.  Have re-installed as well.  Also using latest Radarbox drivers.  Any help much appreciated.
Davidp124
Re: RadarBox Legacy w/Win10 mouse issues
« Reply #1 on: November 06, 2020, 08:41:39 AM »
That is unfortunately an issue with V6.00.03, better using V6.00.02 if you dont use an x-range
biffa18
« Reply #2 on: November 06, 2020, 11:57:53 PM »
is this problem going to be resolved as i have x range ?
GlynH
« Reply #3 on: November 07, 2020, 04:57:09 PM »
So you went with the XRange after all then biffa18?
How long have you been online and what are your first impressions so far?
As I stated in another thread I sent mine back and went with my own Raspberry Pi/FlightStick setup which I am over the moon with having been online for just 3 days so far.
I am seeing the same problem with 6.02.003 (along with many other issues also) but I wonder how much of a priority this might be in this age of mobile apps/web interfaces.
Are you able to change your map preferences and have it reload them the next time you run it or does it always default to its own preferred state leaving you to set it up every single time you open it?
Also if I deselect any Aviation Signs or General Signs then not only does Outlines default back to on but I lose all aircraft from the map only (they are still visible in MyFlights) where the only way to get them back is to disconnect/reconnect from the hardware.
Shame as I would really like to see the legacy software updated but unfortunately I see references to not being able to show the flight by clicking on the map going back to at least January 2019 and guess it is referred to as legacy these days for a reason?
-=Glyn=-
« Last Edit: November 07, 2020, 05:21:59 PM by GlynH »
« Reply #4 on: November 07, 2020, 07:45:34 PM »
I wouldnt see any update any time soon
davidp124
« Reply #5 on: November 08, 2020, 04:26:29 AM »
Thanks Runway31,
Would you have a link for V6.00.02 available?  Thank You again.
David
« Reply #6 on: November 08, 2020, 05:00:36 PM »
davidp124
« Reply #7 on: November 23, 2020, 03:54:58 PM »
Thanks Allan,
Works again!
