Author Topic: How do I see my own flights  (Read 15189 times)
gcopter1
« on: January 03, 2021, 07:18:39 PM »
I recently downloaded the software and managed to point the software to my own Pi3 and adsb receiver.
If I click on the the Network tab and click the Get Flights from RadarBox network, I immediately get to see flights around me, not so when I deselect that and instead click the tab for My Flights.
On the File tab>Preferences>RadarBox New Firmware section, I've set the IP address of the Pi3 and the port it was using before for PlanePlotter.
If I open a webpage with the IP, I can see my data.
I rechecked Windows Firewall settings and ANRB is allowed.
What am I missing?
Re: How do I see my own flights
« Reply #1 on: January 03, 2021, 08:08:44 PM »
I believe it should be
Port: 32088
Host: 192.168.0.21
(replace 192.168.0.21 by your RPi's actual Local IP address)
gcopter1
« Reply #2 on: January 04, 2021, 07:52:48 AM »
Using 32088 as the port, didn't work.
If I use port 30005 (in my previous use with PP), the "Hardware Connected" box is lit green, but no aircraft showing.
  • CYYZ - Toronto
« Reply #3 on: January 04, 2021, 08:31:26 AM »
Have you installed RB24 feeder on RPi?
It is the RB24 feeder which outputs ANRB v6 compatible output at port 32088.
The output at port 30005 is produced by dump1090 and in beast format. The ANRB although shows connected,  does NOT process beast format data, so no planes will be displayed.
DUMP1090 PORT 30005 - DATA IN BEAST FORMAT - WONT BE PROCESSED BY ANRB V6
Code: [Select]
pi@raspberrypi:~ $ nc 127.0.0.1 30005
2i:gX▒▒|:▒^2i▒▒C        ]▒▒▒k▒)3i▒▒:▒▒▒|e▒▒+2j˻X▒▒|:▒^2j▒▒X▒▒|:▒^3k9Hn▒▒▒|e▒▒
+3ka▒d▒▒▒~e▒▒ ▒▒c2k▒▒▒X▒▒|:▒^3k▒▒▒▒▒|e▒▒
+2lX▒X▒▒|:▒^3l▒|▒▒▒|e▒▒ +2l▒▒X▒▒|:▒^3l▒Q
▒▒▒▒~e▒▒ ▒▒c3m4~▒▒▒▒|e▒▒ +2m▒eX▒▒|:▒^3ne▒▒▒|e▒▒
+2n▒]▒▒▒k▒/2n$(]▒▒▒k▒*2nb▒nX▒▒|:▒^3n▒▒▒▒▒▒|▒$▒Hj3n٥K▒▒|e▒▒
+2n▒oX▒▒|:▒^3oQ▒▒▒▒~e▒▒ ▒▒cg3o▒▒▒▒▒|e▒▒
+2o▒▒▒X▒▒|:▒▒▒▒▒X▒▒~▒▒ު▒!2qu▒X▒▒|:▒^3qF▒z▒▒▒~e▒▒ ▒▒c^C▒▒▒▒,T2p=▒Y
     ]▒▒▒k▒!2p▒poX▒▒|:▒^3p▒
RADARBOX RPI FEEDER PORT 32088 - DATA IN SPECIAL FORMAT - WILL BE PROCESSED BY ANRB V6
Code: [Select]
pi@raspberrypi:~ $ nc 127.0.0.1 32088
FmJyZxQFBgoGAwQGBAQOAwYJAQ==~*
FmRjdBR0BgoOBAQYBQUKBgYJBgcCBwUHDQIaFBofHhgbGRQbGhQaHw==~*
FmRjdBR0BghwdgAYBQUKBgYJBgcCBwUHDQIaFBofHhgbGRQbGhQaHw==~*
FmRjdBR2DwABBXcYBQUKBgYJBgcCBwUHDQIaFBofHhgbGRQbGhQaHw==~
« Last Edit: January 04, 2021, 08:58:24 AM by abcd567 »
gcopter1
« Reply #4 on: January 04, 2021, 07:33:27 PM »
No I have not.
Could you please include the steps, it's been a couple of years since I began using my Pi.
I can access the pi via my browser, would I be able to add the RB feeder in this way or would I need to pull out the sd card?
Thanks.
gcopter1
« Reply #5 on: January 04, 2021, 07:54:04 PM »
Ok, I found the instructions on another thread.
If you don't mind, I'll ask follow up questions as I read the instructions.
Thanks.
Gilberto.
gcopter1
« Reply #6 on: January 04, 2021, 07:56:18 PM »
I'm following the instructions set in OPTION 3.
gcopter1
« Reply #7 on: January 04, 2021, 08:00:42 PM »
After typing "/list", I started seeing a lot of scrolling, seems like that command was doing a lot of updating.
At the end, I was presented with the option to install "dump978-rb program"
Waiting for y/n?
At this point, should I type "y"?
gcopter1
« Reply #8 on: January 04, 2021, 08:15:01 PM »
Went ahead and typed "y".
At the end of the process, I'm presented with a message.
What should I do next?
gcopter1
« Reply #9 on: January 04, 2021, 09:31:59 PM »
Takes a while for posts to show up.
Since last post, I entered "y" to accept the install.
After a bunch of scrolling, I found the entries to command the pi to get the key for the rb feeder.
My ARNB now works displaying my own flights.
Although on the pi, I saw lots of messages saying it couldn't connect to 978 something (forgot since I've already closed the pi browser).
Wondering if I should worry about it or leave things as is?
« Reply #10 on: January 04, 2021, 09:38:14 PM »
This will be you on RB24 I presume https://www.radarbox.com/stations/EXTSHA195452
gcopter1
« Reply #11 on: January 04, 2021, 09:45:11 PM »
Don't think so.
From the blue dot position on the map, that's located to the southwest of me.
gcopter1
« Reply #12 on: January 04, 2021, 09:49:32 PM »
Check, EXTRPI020773.
« Reply #13 on: January 04, 2021, 09:52:52 PM »
Edit your location with exact decimal lat/lon to set up MLAT
gcopter1
« Reply #14 on: January 04, 2021, 10:00:27 PM »
On the pi?
What's the command?
On the ANRB locale settings, is precise.
