My station is listed as offline, although rbfeeder sends data
Started by elmicha, August 12, 2017, 10:21:07 AM
elmicha
my station https://www.radarbox24.com/stations/EXTRPI542735 appears to be offline, but /var/log/rbfeeder.log says it is sending data:
[2017-08-12 12:10:07]  ******** Statistics updated every 30 seconds ********
[2017-08-12 12:10:07]  Packets sent in the last 30 seconds: 684, Total packets sent since startup: 1063686
[2017-08-12 12:10:38]  ******** Statistics updated every 30 seconds ********
[2017-08-12 12:10:38]  Packets sent in the last 30 seconds: 795, Total packets sent since startup: 1064481
And restarting rbfeeder also doesn't help, again without any problems reported in the log:
Aug 12 12:11:39 rpi3 rbfeeder[10851]: [2017-08-12 12:11:39]  Starting RBFeeder Version 0.2.3 (build 20170527202345)
Aug 12 12:11:39 rpi3 rbfeeder[10851]: [2017-08-12 12:11:39]  Using configuration file: /etc/rbfeeder.ini
Aug 12 12:11:39 rpi3 rbfeeder[10851]: [2017-08-12 12:11:39]  Network-mode enabled.
Aug 12 12:11:39 rpi3 rbfeeder[10851]: [2017-08-12 12:11:39]                  Remote host to fetch data: 127.0.0.1
Aug 12 12:11:39 rpi3 rbfeeder[10851]: [2017-08-12 12:11:39]                  Remote port: 30005
Aug 12 12:11:39 rpi3 rbfeeder[10851]: [2017-08-12 12:11:39]                  Remote protocol: BEAST
Aug 12 12:11:39 rpi3 rbfeeder[10851]: [2017-08-12 12:11:39]  System: armhf
Aug 12 12:11:39 rpi3 rbfeeder[10851]: [2017-08-12 12:11:39]  Start date/time: 2017-08-12 12:11:39
Aug 12 12:11:45 rpi3 rbfeeder[10851]: [2017-08-12 12:11:45]  Connection established.
Aug 12 12:11:46 rpi3 rbfeeder[10851]: [2017-08-12 12:11:46]  Connection with RadarBox24 server OK! Key accepted by server.
What can I do?
Regards...
  Michael
Looks like it had been working away nicely and then stopped feeding data to RB yesterday morning
Suggest that you contact [email protected] for advice.
CYYZGUY
I had the same problem last night, mine was showing as "Offline" as well for many hours, when I checked this morning, it was feeding again.  I noticed several other feeders were showing "Offline" as well, not only mine.
Jason
40" LED Monitor
40" LED Monitor
Currently my classic station is showing to be offline but if I go to my stations I can see aircraft on screen that are received by that station.
Today after midnight my station was offline for some hours. I did a check and figured out that several other classic hardware stations were offline  at the same time. So apparently the problem seems to be caused at airnavs end.
