airnav flight stick
Started by paulinuk26, January 09, 2021, 02:40:20 PM
paulinuk26
Ballycastle north Ireland and yes hardware is green to be fair no aircraft about at min but i was just wanting to be sure its working and to get upgraded alan
Yes looking at Ireland just now and nothing around so you cant send any data until you pick up some flights.  Once you start sending regular data I should hopefully be able to see you and give you further advice
You will need to contact [email protected] but you will need your sharer number but I cany give you it until you appear on the system
paulinuk26
there are flight right now showing on the system vjt178 active now
Paul
I believe you are picking up 2 aircraft at this time
paulinuk26
yes i am indeed yankie99 also alan
Paul
Your sharer number is EXTSHA195464 https://www.radarbox.com/stations/EXTSHA195464 .  Contact [email protected] advise them of the sharer number and your email address and ask them to link the receiver to your account.
Once done you will be upgraded to Business
paulinuk26
that's for all that alan i just sent to them there now kind regards paul
They usually reply within 24 hours
paulinuk26
thanks for all your help alan appreciate this my antenna is going up to a proper Hight next weekend so will be a lot better thanks again
Paul
Support have not received an email from you.  [email protected] or pass me you email address and i will have them contact you
paulinuk26
hi alan yes please my email is [email protected] thank you
Email address passed to support Paul  I has also replied to your PM's but no reply from you there
paulinuk26
thank you alan appreciate this do i have to wait or how do i change my location to the correct one i have now put up a radarbox antenna with great results so awaiting upgrade thank you again
#28
Once you are upgraded get back to me and I will give guidance.  The location should be to the lat/lon co-ordinates you provided on File/Preferences/Home Station Data, click Apply then OK
paulinuk26
no problems i will contact you as soon as im upgraded i assume this is an email notification thanks for all your help alan
