Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
AirNav Systems Forum
AirNav Radar Discussion
(Moderator:
airnav flight stick
« previous
next »
Print
Pages: [
1
2
3
4
Author
Topic: airnav flight stick (Read 47662 times)
paulinuk26
New Member
airnav flight stick
on:
January 09, 2021, 02:40:20 PM »
hi there please thank you for any help in advance i have purchased a flightstick to feed into the system and i have a windows 10 computer can some help me with what software from here to use this and help to get it up and running kind regards paul
Logged
Moderator
Hero Member
Re: airnav flight stick
Reply #1 on:
January 09, 2021, 03:22:48 PM »
Welcome
Download and install the V6 software from
https://www.airnavsystems.com/download/ANRB/ANRB60002Setup.exe
Please note install to C:\Airnav dont use a Program Files location
You wil also need to instal lthe drivers for the stick from here
http://www.airnavsystems.com/Download/ANRB/Drivers/microRadarbox-Drivers-20150411.exe
Give it time to install, wait til the DOS box disappears
Plug in the stick and start up the software and hopefully all will be well
Logged
paulinuk26
New Member
Reply #2 on:
January 09, 2021, 06:59:44 PM »
hi alan thanks for that info can it seams to pause ever so often is there a way of stopping network flights i would just like to upload what i see on my end to the system and i pay for standard pack do you get an upgrade if i feed into the system thank you regards paul
Logged
Moderator
Hero Member
Reply #3 on:
January 09, 2021, 07:43:04 PM »
Hi Paul
On the newtwork tab, bottom left untick Get Flights From Radarbox Network. It takes quite a bit to download 7/8000 flights every 20 seconds
If you feed into RB24 you upgrade to Business
Logged
paulinuk26
New Member
Reply #4 on:
January 09, 2021, 07:44:27 PM »
thanks alan where do i get that option to feed sorry to be a pain
Logged
Moderator
Hero Member
Reply #5 on:
January 09, 2021, 07:46:08 PM »
I believe you share automatically once you start feeding. Where are you located
Logged
paulinuk26
New Member
Reply #6 on:
January 09, 2021, 07:47:31 PM »
yes im in n Ireland its just new to this and dont know where to put the setting in ect thank you
Logged
Moderator
Hero Member
Reply #7 on:
January 09, 2021, 07:52:10 PM »
Go to File/Preferences/Radarbox and enter your lat/lon in decimal then press Apply and OK and hopefully I can find you
Logged
paulinuk26
New Member
Reply #8 on:
January 09, 2021, 07:56:22 PM »
i have done that alan earlier on but it hasn't upgraded at all m8
Logged
Moderator
Hero Member
Reply #9 on:
January 09, 2021, 07:59:20 PM »
It normally upgrades automatically a short time after you start feeding but I cannot see you. Are you seeing aircraft on your MyFlights tab
Logged
paulinuk26
New Member
Reply #10 on:
January 09, 2021, 08:00:52 PM »
no alan nothing in tabs but all connected up and running can i ask is there a way to make sure im feeding into it
Logged
Moderator
Hero Member
Reply #11 on:
January 09, 2021, 08:03:48 PM »
Paul
Bottom left Hardware connected is it green
Does your antenna have a clear view of the sky
Logged
paulinuk26
New Member
Reply #12 on:
January 09, 2021, 08:04:31 PM »
i have network flights un cheaked and its red but the hardware connected micro/rb is green and working
Logged
paulinuk26
New Member
Reply #13 on:
January 09, 2021, 08:04:57 PM »
yes outside on tower
Logged
Moderator
Hero Member
Reply #14 on:
January 09, 2021, 08:07:37 PM »
OK the hardware connected being green is important and that is good, where in Ireland are you located
What type of antenna do you have and are your cable connections good
Last Edit: January 09, 2021, 08:11:32 PM by Runway 31
Logged
Print
Pages: [
1
2
3
4
« previous
next »
(Moderator:
airnav flight stick
