Author Topic: RBFeeder and Radarbox software  (Read 10617 times)
andrewjwhall
« on: August 14, 2017, 12:20:13 PM »
Hello to the Forum!
I have tried having a look for this answer but with no success.
I am thinking of setting up my Raspberry PI for the RDFeeder to run 24/7. My question is if I were to install the RadarBox windows software on my PC (Windows 10 pro) could I connect to the PI via my home network to view the aircraft on my desktop rather than the RadarBox24 website?
I find the software (in demo mode) quite good and would like to use it further.
Would be most grateful for any help/pointers!
Best Regards,
Andrew Hall
Re: RBFeeder and Radarbox software
« Reply #1 on: August 14, 2017, 03:12:59 PM »
Unfortunately it is not possible to connect a RPi running dump1090 (or any other feeder software) with RadarBox Windows software via LAN.
RadarBox Windows is currently working with the following options:
Classic RadarBox Hardware
RadarBox Constation via LAN (Buggy and unstable)
RadarBox Micro SDR based Stick or
any other generic R820T(2) /RTL2832U based SDR stick if alternative zadic drivers are installed on PC
andrewjwhall
« Reply #2 on: August 14, 2017, 08:50:16 PM »
Okay! Thank you for the answer to my question!
Best Regards,
Andrew.
