Range Rings
Started by Turbo, January 30, 2021, 01:34:30 PM
Turbo
Is there a way of not havng them i find them annoying on my XRange 2  also how do i know what the distance from my location is on aircraft thanks..
Regards Lino.
#1
As far as I am aware there is no way of removing them.  Regarding the distance of aircraft from your location the range rings can give you an idea of the distance
Have you considered connecting your xrange to the Airnav V6 software as that gives the exact distance
Turbo
How do i get that software also usually i have an idea by looking at my other adsb receivers...
Lino..
Turbo
Thanks will have a go at it..
Lino.
It connects through your home network and it set up through File/Preferences where you set up your IP etc
Turbo
Hi Alan those links i cannot acess.
Lino.
The links dont appear to be working as expected, use Open Link in New Window and they download OK.  I will advise Airnav to correct the link workings
https://www.radarbox.com/legacy-software is working as expected and if you scroil down the page you will see the links
Turbo
That link works thanks do i download all of them.
Limo.
GlynH
Also you will need to go to File/Preferences/Radarbox/ and at the bottom of the left hand side where it says RadarBox New Firmware (which is a little misleading IMHO) IP Address which will be the IP Address of your XRange and also port which should default to 32088
Just bear in mind that when using v6.02.003 you will lose the ability to click on an aircraft on the radar screen and have it highlighted in MyFlights!
It would appear that AirNav have no interest in fixing this fundamental issue...<sigh>
Thanks & kind regards,
-=Glyn=-
He didnt have the ability in the first place so no loss.  Thankfully I dont have the issue not a having a Pi or an xrange just a plain old Windows computer so can stay with 6.00.02 .  Sometimes its a blessing being behind with advances!!
It also works with my BBC B computer !
