Dedicated UAT Pi won't feed
Started by thespeedycab, March 12, 2021, 04:09:56 PM
thespeedycab
All
I have a dedicated UAT pi, that has dump978-fa running, and feeds FA without a problem. It is a PiAware SD-card 5.0. But I can't get it to feed RB. There is no 1090 and MLAT. On the pi I see the following:
Quotepi@piaware:~ $ sudo rbfeeder --status
[2021-03-12 08:05:27]  Starting RBFeeder Version 0.3.5 (build 20200727132301)
[2021-03-12 08:05:27]  Using configuration file: /etc/rbfeeder.ini
[2021-03-12 08:05:27]  Network-mode enabled.
[2021-03-12 08:05:27]        Remote host to fetch data: 127.0.0.1
[2021-03-12 08:05:27]        Remote port: 30005
[2021-03-12 08:05:27]        Remote protocol: BEAST
Error opening the listening port 32458 (Raw TCP output): bind: Address already in use
[2021-03-12 08:05:27]  Error opening the listening port 32458 (Raw TCP output): bind: Address already in use
Error opening the listening port 32457 (Beast TCP output): bind: Address already in use
[2021-03-12 08:05:27]  Error opening the listening port 32457 (Beast TCP output): bind: Address already in use
Error opening the listening port 32459 (Basestation TCP output): bind: Address already in use
[2021-03-12 08:05:27]  Error opening the listening port 32459 (Basestation TCP output): bind: Address already in use
Error opening the listening port 32008 (Raw TCP input): bind: Address already in use
[2021-03-12 08:05:27]  Error opening the listening port 32008 (Raw TCP input): bind: Address already in use
Error opening the listening port 32004 (Beast TCP input): bind: Address already in use
[2021-03-12 08:05:27]  Error opening the listening port 32004 (Beast TCP input): bind: Address already in use
[2021-03-12 08:05:27]  System: raspberry
[2021-03-12 08:05:27]  Start date/time: 2021-03-12 08:05:27
[2021-03-12 08:05:27]  Bind failed on ANRB channel. Port: 32088
[2021-03-12 08:05:28]  Connection established.
[2021-03-12 08:05:30]  Can't connect to external source (127.0.0.1:30005). Waiting 5 second...
It just goes on.
I can see AC locally on the Pi. But on the radarbox site, it notes zero message, though the total is 108 (0+0+0=108, apparently).
Any tips appreciated
You need to modify settings under [dump978] in file /etc/rbfeeder.ini
Please see following post for details:
https://forum.radarbox24.com/index.php?topic=103271.msg444091#msg444091
thespeedycab
#2
Hey @adcb567
that solves one problem: I now see UAT on RB.  In
Quotesudo rbfeeder --status
I still have the cannot connect message:
Quote
[2021-03-12 10:51:48]  Can't connect to external source (127.0.0.1:30005). Waiting 5 second...
[2021-03-12 10:51:53]  ******** Statistics updated every 30 seconds ********
[2021-03-12 10:51:53]  Packets sent in the last 30 seconds: 142, Total packets sent since startup: 849
[2021-03-12 10:51:53]  Data sent: 30.1 KB
[2021-03-12 10:51:53]  Data received: 1.1 KB
[2021-03-12 10:51:53]  Can't connect to external source (127.0.0.1:30005). Waiting 5 second...
[2021-03-12 10:51:58]  Can't connect to external source (127.0.0.1:30005). Waiting 5 second...
[2021-03-12 10:52:03]  Can't connect to external source (127.0.0.1:30005). Waiting 5 second...
Thoughts on this one?
Fun fact: UAT feeder also sends TIS-B data!
#3
This message will be there since the setting under [network] in file /etc/rbfeeder.ini are as follows, but there is no dump1090 running to provide data on port 30005
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
You may either ignore it, or change "external_port=30005" to "external_port=30979". This may or may not work. Try it, if it creates problem, change port number back to 30005.
Dont forget to save file then restart rbfeeder after every time you make a change in file /etc/rbfeeder.ini
thespeedycab
that has done the trick
thx, abcd
