Author Topic: Installing airnav on windows 10 pc  (Read 21881 times)
deedaa_andy
« on: May 04, 2021, 02:36:49 PM »
Hi is there any kind person on this forum would help me to install my airnav radar box on to my pc.
Re: Installing airnav on windows 10 pc
« Reply #1 on: May 04, 2021, 02:48:35 PM »
Download and install the V6 software https://www.airnavsystems.com/download/ANRB/ANRB60002Setup.exe into c:\ Airnav dont install to program files location
Download and install the drivers for it https://www.airnavsystems.com/Download/ANRB/Drivers/ANRB-Drivers-20161222.zip
Connect the box and start up the software hopefully all should be OK
« Last Edit: May 04, 2021, 03:26:03 PM by Runway 31 »
deedaa_andy
« Reply #2 on: May 08, 2021, 09:12:43 AM »
Dear runway 31 I have carried out what you said to the letter but no joy still cound not make it work.
« Reply #3 on: May 08, 2021, 03:03:03 PM »
No idea what to advise you Andy.  It should just a matter of instaling the software, connecting the equipment and powering up and starting the software
Its impossible for me to see what you are doing from a distance
project.loveridge
« Reply #4 on: January 22, 2022, 02:35:21 PM »
Hi deedaa_andy
Did you manage to get yours to work?
I have installed the software to Windows 10, Installed the drivers, Connected the antenna, opened the software, but nothing is showing on the Map...  There are aircraft flying closeby (confirmed on online ADS-B feeds).
Many thanks
« Reply #5 on: January 22, 2022, 07:54:10 PM »
Whar receiver are you using?
sparks240
« Reply #6 on: March 14, 2022, 05:14:00 PM »
I am trying to reinstall Airnav v6 software and the drivers zip file on my windows 10 pc from the Airnav website.
I am blocked from doing this, I think from the McAfee protection software on the pc.
This is the message I receive.
"You can't visit www.airnavsystems.com right now because its certificate has been revoked. Network errors and attacks are usually temporary, so this page will probably work later."
Advice would be welcome how to overcome this problem.
Many thanks.
Reg
« Reply #7 on: March 14, 2022, 05:22:57 PM »
Suggest that you try pausing your anti-virus and try again
I use Norton and have just tried them here and they are downloading with no issues
Remeber and restart the AV once done
sparks240
« Reply #8 on: March 14, 2022, 09:44:32 PM »
Hi Alan
Thanks for the advice, and also for seeing if you can gain access to the sites, to confirm the problem is at my end. I will do what you suggest tomorrow when I have more time.
Regards.
Reg
project.loveridge
« Reply #9 on: May 21, 2022, 01:30:56 PM »
Hi Runway 31
Im having exactly the same issue you described. Were you able to fix it on your end?
Kind regards
project.loveridge
« Reply #10 on: May 21, 2022, 03:45:54 PM »
Sorry. Meant for SPARKS240
Did you manage to get yours working?
« Reply #11 on: May 21, 2022, 05:11:52 PM »
Can you advise the issues you are having?
project.loveridge
« Reply #12 on: May 21, 2022, 06:39:18 PM »
Ive downloaded the Software and also the Driver Installer. Followed the steps on the RadarBox website but for some reason the Drivers never gets loaded or recognised by Windows. When I go to Device Manager and manually try to update the Drivers, it states it could not update.
I then contacted Support, who sent me the advice below, but it results in "the driver update failed":
1.) Restart your machine. Ensure nothing is running and connect the FlightStick
2.) Download the Zagdig software from
https://github.com/pbatard/libwdi/releases/download/b721/zadig-2.4.exe
3.) Run the zadig-2.4.exe in Admin mode.
Open the Zadig executable and choose "Bluk-In, Interface (Interface 0)". If no device is shown select Options -> List all devices and see if appears (it will be RTL382..). In any case, it must shown at least "1 device found".
The driver to be selected is WinUSB on the selection below and then click install driver/replace driver.
I have uninstalled the Software and drivers several times to re-attempt the installation, with no avail.
The AirNav Software opens up, but it states "Hardware not Connected" so no airtracks are displayed.
Thank you for your assistance.
« Reply #13 on: May 21, 2022, 07:11:38 PM »
What receiver are you using, the original radarbox or the flightstick?
When you run Zadig to install the drivers is the istaller like the attached
« Last Edit: May 21, 2022, 07:22:19 PM by Runway 31 »
project.loveridge
« Reply #14 on: May 21, 2022, 07:16:22 PM »
The RadarBox ADS-B FlightStick
