Some interesting findings....NOOELEC vs Airnav Classic radarbox
Started by CYYZGUY, August 27, 2017, 08:41:26 PM
CYYZGUY
For about 2 weeks now, I have been running 2 systems, off the same ADSB antenna I have perched high up outside.... with a splitter.
On the radarbox classic, I get more hits, for example, I have 158 aircraft showing.
On the NOOELEC, I have 132 aircraft showing.
Now, with the same antenna, you would think the results should be the same.....give or take a few aircraft, but the NOOELEC has consistently about 20 less aircraft showing....and most of them are MODE-S only not showing up..
Now, here is the bizarre part.  The range on the NOOELEC is outstanding, I get hits much further away.
Max range on the NOOELEC is 336 Nm
Max range on radarbox classic is 243 Nm
My conclusion so far is that the NOOELEC does BETTER with ADSB signals then the radarbox classic, but the radarbox classic get more MODE-S hits.
Just throwing it out there for everyone to see.
Jason
40" LED Monitor
40" LED Monitor
tommyg
Jason.
After my classic box died i have fitted the NooElec dongle (which doesn't work with my tablet unlike my old classic RB, but thats another story) to my laptop and using the same external antenna I agree with you that the number of ADSB hits seems to be the same but MODE S only seems to have reduced so where as i was getting on average 70/80 flights on my my system its now down to 50/60 and mainly ADSB.
tommyg
Tommyg
