Author Topic: Driver  (Read 9512 times)
Erich
Driver
« on: May 14, 2021, 07:10:02 PM »
Hello in the forum!
Wechen drivers for the green ADSB
Flightstick Alen please the correct driver ???
Lg Erich
Re: Driver
« Reply #1 on: May 14, 2021, 08:48:11 PM »
Erich
Re: Driver
« Reply #2 on: May 15, 2021, 07:53:54 AM »
Hello in the forum!
I installed the driver https://www.airnavsystems.com/Download/ANRB/Drivers/microRadarbox-Drivers-20150411.exe in AirNav ADS-B Flight Stick and waited until the
Black box has turned off by itself. Driver is present in AirNav driver
And exe ran though
In the device manager not to be found how should the loud ??? What am I doing wrong.
Asking for help Alen must have some advice. LG Erich
Re: Driver
« Reply #3 on: May 15, 2021, 02:38:41 PM »
You should see it in Control Panel/Devices and Printers/Unspecified and is names RTL2832U
If you cannot get it to work also try the Zadig drivers from https://zadig.akeo.ie/
Erich
Re: Driver
« Reply #4 on: May 18, 2021, 08:42:36 AM »
Hello Alan!
My ADSB Flight Stick works under RTL 2838UHIDIR
Impeccable thanks for your help.
LG Erich
Re: Driver
« Reply #5 on: May 18, 2021, 08:44:45 AM »
Great Erich
Geot
Re: Driver
« Reply #6 on: May 21, 2021, 09:37:26 PM »
Hi Alan, just received my Flightstick and having same problem so thought I would jump on this Topic.
I was running 6.01.001 with a MicroRB. I simply inserted the Flstck and ran the Drivers update as mentioned above. When opening RB, it does not recognize the Device.
Looking in Control Panel as above I see the RTL2838. It shows Driver as unavailable. A right click on Properties shows Hardware with 2 Bulk-in, Interfaces and a USB Composite Device - the latter shows working OK but the two Bulk-ins show Drivers not installed and No compatible drive available. Running Troubleshooting does nothing.
Re-running the Drivers.exe does nothing.
Any suggestions?
GeorgeT
  • CYYZ - Toronto
Re: Driver
« Reply #7 on: May 21, 2021, 11:10:23 PM »
Hi Geot
(1) Download Zadig.exe from http://zadig.akeo.ie/ .
(2) Plug the Dongle (FlightStick or ProStick or DVB-T) in your Windows Computer.
(3) Follow the steps below:
Double click Zadig.exe to run it.
The window below will open.
On main menu, click “Options”.
On the drop-down, place a check mark beside “List All Devices”.
From list of devices, select “RTL2838” which is actually DVB-T or FlightStick or ProStick.
Now click button which will either say “Install Driver” or “Reinstall Driver”
Geot
Re: Driver
« Reply #8 on: May 22, 2021, 01:53:36 AM »
Hi Alan, I managed to screw up my computer, will get back to you when fixed
thanks
GeorgeT
Geot
Re: Driver
« Reply #9 on: May 22, 2021, 09:43:29 PM »
Hi Alan, all fixed and working, great improvement over my MicroRB.
Note, when the Flightstick is inserted on the PC, in Device Manager it did not show as UTL..., but as "Bulk-in, Interface", times two, and that was what I had to look for on Zagit.
Just in case someone else has a similar problem
cheers
GeorgeT
Re: Driver
« Reply #10 on: May 22, 2021, 09:49:52 PM »
Cheers George, glad you are back up and running
