Author Topic: rbfeeder receives dump1090-fa, but isn't sending anything to Radarbox  (Read 15181 times)
wooter
I have an odd one here.
My rbfeeder setup went smoothly, and airplane positions show up in /var/log/rbfeeder.log, but my Sharing Key is not found in RadarBox, and according to rbfeeder.log no packets are sent.
 A snapshot from rbfeeder.log:
Code: [Select]
2021-05-21 16:44:07]  Starting RBFeeder Version 0.4.1 (build 20210414164501)
[2021-05-21 16:44:07]  Using configuration file: /etc/rbfeeder.ini
[2021-05-21 16:44:07]  Network-mode enabled.
[2021-05-21 16:44:07]  Remote host to fetch data: 127.0.0.1
[2021-05-21 16:44:07]  Remote port: 30005
[2021-05-21 16:44:07]  Remote protocol: BEAST
[2021-05-21 16:44:07]  System: rblc2
[2021-05-21 16:44:07]  Start date/time: 2021-05-21 16:44:07
[2021-05-21 16:44:07]  Socket for ANRB created. Waiting for connections on port 32088
[2021-05-21 16:44:09]  Connection established.
[2021-05-21 16:44:10]  [471F6E] P: 20620.646 vtas: 456.000 vias: 245.000 Alt: 38025 mach: 0.776 VTAS: 456.000 VTAS2: 234.586 Temp: 227.401 (-45.749 C) Temp 2: -50.377 Temp 3: -25.084
[2021-05-21 16:44:13]  [471F6E] P: 20620.646 vtas: 456.000 vias: 245.000 Alt: 38025 mach: 0.776 VTAS: 456.000 VTAS2: 234.586 Temp: 227.401 (-45.749 C) Temp 2: -50.377 Temp 3: -25.084
[2021-05-21 16:44:16]  [471F6E] P: 20620.646 vtas: 456.000 vias: 245.000 Alt: 38025 mach: 0.776 VTAS: 456.000 VTAS2: 234.586 Temp: 227.401 (-45.749 C) Temp 2: -50.377 Temp 3: -25.084
[2021-05-21 16:44:19]  Could not start connection. Timeout.
[2021-05-21 16:44:19]  [471F6E] P: 20620.646 vtas: 456.000 vias: 245.000 Alt: 38025 mach: 0.776 VTAS: 456.000 VTAS2: 234.586 Temp: 227.401 (-45.749 C) Temp 2: -50.377 Temp 3: -25.084
[2021-05-21 16:44:37]  ******** Statistics updated every 30 seconds ********
[2021-05-21 16:44:37]  Packets sent in the last 30 seconds: 0, Total packets sent since startup: 0
[2021-05-21 16:44:37]  Data sent: 50 B
[2021-05-21 16:44:37]  Data received: 0 B
This "Connection established" and "Could not start connection. Timeout." happens in regular intervals, and each 30s the statistics are shown that there are 0 packets sent.
So to me it looks dump1090 is working fine, rbfeeder is receiving its data but no packets are sent to RB.
Any clues where I should be looking? The RPi resolves radarbox24.com and radarbox.com
  • CYYZ - Toronto
Did you claim your station?
If not, then to claim, please follow instructions here:
https://www.radarbox.com/raspberry-pi/claim
wooter
When trying to claim, I get the error "Sharing Key not found".
I assume this is because rpfeeder hasn't been able to connect to RadarBox yet to publish the key.
  • CYYZ - Toronto
Reboot the Pi and check if key has been obtained.
The latest version of rbfeeder (0.4.1-20210414164501), fails to start/restart by systemd command "sudo systemctl restart rbfeeder", and and hence fails to obtain the key. The only way left to restart rbfeeder is to Reboot the Pi (sudo reboot).
« Last Edit: May 21, 2021, 09:24:52 PM by abcd567 »
wooter
I'm sorry, but that didn't do anything either.
I keep seeing these messages, even after rebooting:
Code: [Select]
[2021-05-22 10:01:13]  Connection established.
[2021-05-22 10:01:18]  ******** Statistics updated every 30 seconds ********
[2021-05-22 10:01:18]  Packets sent in the last 30 seconds: 0, Total packets sent since startup: 0
[2021-05-22 10:01:18]  Data sent: 29.4 KB
[2021-05-22 10:01:18]  Data received: 0 B
[2021-05-22 10:01:23]  Could not start connection. Timeout.
And the Sharing Key is still not found to claim my RPi.
Any other ideas? :)
Try contacting [email protected] for advice
  • CYYZ - Toronto
Does the output of this command not show the key?
Code: [Select]
sudo rbfeeder --showkey --no-start
You can find the key by following command also:
Code: [Select]
cat /etc/rbfeeder.ini
wooter
That command shows the key.
But the key is not recognised on the Radarbox website.
  • CYYZ - Toronto
Try this:
First delete the file /etc/rbfeeder.ini and purge the installed rbfeeder by following commands
Code: [Select]
sudo rm /etc/rbfeeder.ini
sudo apt-get purge rbfeeder
sudo reboot
After reboot Install rbfeeder again, and get new key.
Code: [Select]
sudo apt-get install rbfeeder
Now try to claim using new key.
« Last Edit: May 22, 2021, 11:07:45 AM by abcd567 »
wooter
Followed that, no change. Still the same behaviour, and the new key is also not recognised by Radarbox.
  • CYYZ - Toronto
As already suggested by Alan, try contacting [email protected] for advice
There is some sharing key issues that have been escalated to our development team.
nbarros
I’m +1 with this issue, my setup seems ok (with 1090-fa feeds FA, Fr24, PlaneFinder) but the key is not accepted by the radarbox claim page. Lost count of how many abcd567’s troubleshooting posts I read after so many google searches. Following up with the thread.
See previous post, there is an issue with keys which has been passed to the developers for correction
efece
Any updates on this bug?
Still unable to upload my data and finish the claim process.
Code: [Select]
[2021-05-27 09:14:09]  [A38C95] P: 47039617051387033513099264.000        vtas: 440.000   vias: 250.000  Alt: 35850       mach: 0.756     VTAS: 440.000 VTAS2: 226.355   Temp: 223.074 (-50.076 C)       Temp 2: -50.377         Temp 3: -1.008
[2021-05-27 09:14:09]  [A57A1D] P: 71549210994628537612238848.000        vtas: 484.000   vias: 323.000  Alt: 26750       mach: 0.796     VTAS: 484.000 VTAS2: 248.991   Temp: 243.473 (-29.677 C)       Temp 2: -50.377         Temp 3: 136.617
[2021-05-27 09:14:10]  Could not start connection. Timeout.
