Did the update
Started by [email protected], October 03, 2021, 04:20:04 PM
Hello,
I did the update to the raspberry PI :
sudo apt-get update
sudo apt-get install rbfeeder
And now no data seems to be making it to the web site. Any ideas on what to even look for?
[client]
network_mode=true
disable_log=0
key=xxx
sn=xxx
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
[dump978]
#dump978_enabled=true
What Linux version are you using?
I ran this command
cat /etc/debian_version
and got 10.4
My station is EXTRPI006150 if that might help. Thank you
Dave
markr468
try these commands....
apt-cache policy rbfeeder
cat /etc/os-release
I belive you have an old O/S and suggest that you have a read at the second last mesage on this thread to upgrade your O/S https://forum.radarbox24.com/index.php?topic=105521.0
markr468 Thank you for the commands and I will add them to my list of commands!
Runway 31 I believe you was right about the update. I did it but still no data, however that did lead me to the dongel witch got so hot it melted the outside to a sticky gell. I broke out my old dongel and worked right away but it was linked to my old account. I am not sure how to retreve the old  key. I run the sudo rbfeeder --showkey command and I get the old account EXTRPI027062. Still good news tho I am back up and running.
[email protected] should be able to assist with that issue
