Planes disappear from webview
Started by glen4cindy2, November 17, 2021, 04:00:48 AM
glen4cindy2
I just updated my entire Pi with a new image and added Radarbox as one of my feeders.
That was a few days ago and as far as I know, everything has been running fine.
This evening we had some warmer weather so I took advantage of it and relocated my antenna outside. This will probably be our last warm day!
Since my antenna is outside and higher now I decided to try and run the MLAT commands. Those seem to have worked but I have noticed this evening as I check my page there are no planes being displayed at all.
If I immediately go to some of the other feeders or check to make sure dump1090 is feeding data, it is.
Maybe the best fix is to just uninstall all of the rbfeeder application and data and reinstall but I'm not sure how to do this.
Thanks in advance.
abcd567
#1
Quote from: glen4cindy2 on November 17, 2021, 04:00:48 AM
STEP (1) - NOTE & SAVE YOUR KEY
sudo nano /etc/rbfeeder.ini
Copy your key from above file, paste in Notepad, and save Notepad
STEP (2) - UNINSTALL
sudo apt-get purge mlat-client
sudo apt-get purge rbfeeder
sudo rm /etc/rbfeeder.ini
sudo reboot
STEP (3) - RE-INSTALL
sudo rbfeeder --setkey xxxxxxxxxxx
## replace xxxxxxxxxx by the key you have noted and saved in STEP (1)
## press Ctrl and C keys togather to break out
sudo apt-get install mlat-client
sudo reboot
Enjoy!
