Author Topic: VHF Config check please  (Read 10457 times)
RZEE
« on: December 30, 2021, 09:50:51 PM »
Can a expirianced user tell me if this airband setup is correct ?
Does this scan 4 frequency's from the same dongle?
Code: [Select]
This is a minimalistic configuration file for rtl-airband
# Please change frequencies that you will use and other settings.
# Note: this configuration will use your second dongle attached
# to you raspberry, not the first one!
# index = 0     => First dongle
# index = 1     => Second dongle
devices:
  type = "rtlsdr";
  index = 1;
  gain =28;
  correction = 0;
  mode = "scan";
  channels:
          #squelch = 35;  # Uncomment to set squelch manually
      freqs = ( 118105000, 118280000, 118955000, 119225000 );
      afc=1;
      labels = ( "Schiphol Tower (Runway 18R – 36L)", "Schiphol Tower (Runway 18C – 36C / 09 – 27)", "Schiphol Tower (Runway 06 – 24)", "Schiphol Tower (Runway 18L – 36R)" );
      outputs: (
        { type = "icecast"; server = "audio.rb24.com"; port = 8000;
          mountpoint = "EXTVHF00000A";
          name = "Schiphol Tower (Runway 18R – 36L)";
          description = "Runway 18R - 36L";
          genre = "ATC";
          username = "XXXX";
          password = "XXXX";
          send_scan_freq_tags = true;        },
          type = "icecast";
          port = 8000;
          mountpoint = "EXTVHF00000B";
          name = "Schiphol Tower (Runway 18C – 36C / 09 – 27)";
          genre = "ATC";
          username = "XXXX";
          password = "XXXX";
          type = "icecast";
          port = 8000;
          mountpoint = "EXTVHF00000C";
          name = "Schiphol Tower (Runway 06 – 24)";
          genre = "ATC";
          username = "XXXX";
          password = "XXXX";
          type = "icecast";
          port = 8000;
          mountpoint = "EXTVHF00000D";
          name = "Schiphol Tower (Runway 18L – 36R)";
          genre = "ATC";
          username = "XXXX";
          password = "XXXX";
                # If you need more outputs, put here
Thanks in advance !
Aerotower
Re: VHF Config check please
« Reply #1 on: January 02, 2022, 06:05:39 PM »
NO
Use Multichannel mode!
Something like this
Code: [Select]
  disable = false;
  type = "rtlsdr";
  serial = "00000050"; #RadarboxVHF
  gain = 36.4;
 #Gain values: 19.7 20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6
  correction = 0;
  centerfreq = 130.25;
  mode = "multichannel";
  sample_rate = 1.6;
  buffers = 5;
  channels:
#squelch_threshold = 7;  # Uncomment to set squelch manually
      freq =  130.1;
      labels = ( "LPBJ-App" );
      outputs: (
disable = false;
type = "icecast";
server = "127.0.0.1";
port = 8000;
mountpoint = "LPBJ-APP";
name = "LPBJ-APP";
genre = "ATC";
username = "source";
password = "pass";
description = "Beja Approach";
disable = false;
type = "icecast";
         port = 8000;
         mountpoint = "EXTVHF000138";
         name = "LPBJ-APP";
         genre = "ATC";
         username = "email";
         password = "pass";
disable = false;
type = "file";
directory = "/var/www/html/vhf/LPBJ-APP";
filename_template = "LPBJ-APP";
continuous = false;
split_on_transmission = false;
append = false;
      freq =  130.4;
      labels = ( "LPBJ-TWR" );
      outputs: (
disable = false;
type = "icecast";
port = 8000;
mountpoint = "LPBJ-TWR";
name = "LPBJ-TWR";
genre = "ATC";
username = "email";
password = "pass";
description = "Beja Tower";
disable = false;
type = "icecast";
         port = 8000;
         mountpoint = "EXTVHF000505";
         name = "LPBJ-TWR";
         genre = "ATC";
         username = "email";
         password = "pass";
disable = false;
type = "file";
directory = "/var/www/html/vhf/LPBJ-TWR";
filename_template = "LPBJ-TWR";
continuous = false;
append = false;
You have rtl_airband or rtl-airband-rb??
« Last Edit: January 02, 2022, 06:17:40 PM by Aerotower »
RZEE
« Reply #2 on: January 05, 2022, 08:02:20 PM »
Thanks for your response, i will look into this !
Aerotower
« Reply #3 on: January 05, 2022, 08:34:22 PM »
We are here to help :D
aklTN
« Reply #4 on: May 05, 2023, 09:39:01 PM »
NO
Something like this
Code: [Select]
  disable = false;
  type = "rtlsdr";
  gain = 36.4;
  correction = 0;
  sample_rate = 1.6;
  buffers = 5;
  channels:
      freq =  130.1;
      outputs: (
disable = false;
type = "icecast";
port = 8000;
name = "LPBJ-APP";
genre = "ATC";
password = "pass";
disable = false;
type = "icecast";
         port = 8000;
         name = "LPBJ-APP";
         genre = "ATC";
         username = "email";
         password = "pass";
disable = false;
type = "file";
continuous = false;
append = false;
      freq =  130.4;
      outputs: (
disable = false;
type = "icecast";
port = 8000;
name = "LPBJ-TWR";
genre = "ATC";
username = "email";
password = "pass";
disable = false;
type = "icecast";
         port = 8000;
         name = "LPBJ-TWR";
         genre = "ATC";
         username = "email";
         password = "pass";
disable = false;
type = "file";
continuous = false;
append = false;
If configuring multiple frequencies on a single rtl-sdr, would you use one Serial Key to feed AirNav RadarBox?
