Author Topic: no uat data  (Read 11382 times)
no uat data
« on: February 26, 2022, 10:31:20 PM »
i installed both 1090 and 978 according to radarboxs directions changed 978 dongle as per directions but im still not getting the UAT data
Re: no uat data
« Reply #1 on: February 27, 2022, 02:46:57 PM »
You have not given very much detail on what you have installed
However see this thread and links contained https://forum.radarbox24.com/index.php?topic=105891.0 and se if these help
« Last Edit: February 27, 2022, 02:50:22 PM by Runway 31 »
Re: no uat data
« Reply #2 on: February 27, 2022, 05:09:52 PM »
ive only installed the 1090 and 978 dongles totally fresh raspberry ive only installed the radarboxs software so no other adbs i changed the serial on the 978 just as the instructions had stated changed the 978 port and still no luck
Re: no uat data
« Reply #3 on: February 27, 2022, 05:23:41 PM »
Are you getting 1090 OK and can you show your ini file with your key details blocked out
Re: no uat data
« Reply #4 on: February 27, 2022, 06:00:33 PM »
i wonder if its the dongle i just plugged the green onr in lost all 1090 plugged my original rtl back in and 1090 works just fine
Re: no uat data
« Reply #5 on: February 27, 2022, 06:40:46 PM »
Cant really see anything wrong in your ini file althought I would suggest that you enable MLAT by changing false to true
The issue may be something to do with the sticks, I presume you renumbered them 0 and one etc
Re: no uat data
« Reply #6 on: February 27, 2022, 06:43:19 PM »
im gonna try i happen to have 2 generic rtl just laying around
Re: no uat data
« Reply #7 on: February 27, 2022, 06:50:04 PM »
I presume you have the red Airnav UAT 978 stick
Re: no uat data
« Reply #8 on: February 27, 2022, 07:01:00 PM »
its the 978 station set radarbox sent out for free
Re: no uat data
« Reply #9 on: February 27, 2022, 07:13:33 PM »
ok thanks
Re: no uat data
« Reply #10 on: February 27, 2022, 08:03:28 PM »
so it looks like that setup just picked up 1 packet of uat
Re: no uat data
« Reply #11 on: February 27, 2022, 08:06:50 PM »
That a start and shows that it is working, just need to get some for UAT flights around you
Whats your station?
« Last Edit: February 27, 2022, 08:08:21 PM by Runway 31 »
Re: no uat data
« Reply #12 on: February 27, 2022, 10:43:36 PM »
EXTRPI016198
i have both radarbox dongles plugged in with a different power supply seems to be picking up uta now
Re: no uat data
« Reply #13 on: February 28, 2022, 08:10:49 AM »
Yes seems to be working ok, welcome and thanks for feeding
