Author Topic: Where's a Help File or Tutorial for RadarBox24?  (Read 9304 times)
gregew
« on: September 29, 2017, 02:45:03 AM »
I just subscribed at the $25/year level, and just registered in the Forum because I can't find the usual Help or Tutorials one finds in software.
So is there such a thing?  I do hope so--I don't want to have to use this Forum every time I have some little question.  I'd rather read up on a Manual or some such.
Oh, and I'm not a pro user--I see there's something about hardware in a video I found, but I'm just using it on a PC screen when logging into RadarBox24.com.
Re: Where's a Help File or Tutorial for RadarBox24?
« Reply #1 on: September 29, 2017, 04:39:03 AM »
Unfortunately there isn't a manual for RadarBox24.com website available (yet).
On the other hand: The very small count of questions about usage of RB24.com here on the forum suggests, that the usage is intuitive enough to make such a manual not necessarily required.
So, if you are running into a problem you may ask your question or describe your problem here on the forum or you could contact [email protected] directly.
Regards Ingo
« Reply #2 on: September 29, 2017, 07:29:40 AM »
As Ingo states there is not really a lot to viewing Radarbox24 and the easiest way if you have any queries is to ask on here
The hardware you mention is different in that it is used to provide some of the data feeds used to display the aircraft on Radarbox24.
« Last Edit: September 29, 2017, 07:32:14 AM by Runway 31 »
