Author Topic: Reinstalled and refuses to work !!!!!  (Read 16968 times)
Av8tor_from_Argentina
« on: March 28, 2022, 01:07:26 PM »
Good morning. As the subject stats, I´ve reinstalled the app again (reformatted SD card, Bullseye OS) and Installed Flightradar, Flightaware (both works fine) but radarbox refuses to work. In previous installation the 3 were working fine...
Marco@raspberry:~ $ sudo systemctl status rbfeeder
     Active: active (running) since Fri 2022-03-25 17:24:07 -03; 2 days ago
    Process: 484 ExecStartPre=/bin/mkdir /var/run/rbfeeder (code=exited, status=0/SUCCESS)
    Process: 493 ExecStartPre=/bin/chown rbfeeder:rbfeeder /var/run/rbfeeder (code=exited, status=0/SUCCESS)
    Process: 497 ExecStartPre=/bin/touch /var/log/rbfeeder.log (code=exited, status=0/SUCCESS)
    Process: 511 ExecStartPre=/bin/chown rbfeeder:rbfeeder /var/log/rbfeeder.log (code=exited, status=0/SUCCESS)
    Process: 515 ExecStartPre=/bin/chown rbfeeder:rbfeeder /etc/rbfeeder.ini (code=exited, status=0/SUCCESS)
    Process: 520 ExecStartPre=/bin/setfacl -m u:www-data:rwx /etc/rbfeeder.ini (code=exited, status=0/SUCCESS)
   Main PID: 528 (rbfeeder)
      Tasks: 9 (limit: 1597)
        CPU: 15min 23.306s
             └─528 /usr/bin/rbfeeder
Mar 28 10:00:39 raspberry rbfeeder[528]: [2022-03-28 10:00:39]  ******** Statistics updated every 60 seconds ********
Mar 28 10:00:39 raspberry rbfeeder[528]: [2022-03-28 10:00:39]  Packets sent in the last 60 seconds: 1, Total packets sent sinc>
Mar 28 10:00:39 raspberry rbfeeder[528]: [2022-03-28 10:00:39]  Data sent: 211.4 KB
Mar 28 10:00:39 raspberry rbfeeder[528]: [2022-03-28 10:00:39]  Data received: 0 B
Mar 28 10:01:26 raspberry rbfeeder[528]: [2022-03-28 10:01:26]  Connection established.
Mar 28 10:01:37 raspberry rbfeeder[528]: [2022-03-28 10:01:37]  Could not start connection. Timeout.
Mar 28 10:01:40 raspberry rbfeeder[528]: [2022-03-28 10:01:40]  ******** Statistics updated every 60 seconds ********
Mar 28 10:01:40 raspberry rbfeeder[528]: [2022-03-28 10:01:40]  Packets sent in the last 60 seconds: 1, Total packets sent sinc>
Mar 28 10:01:40 raspberry rbfeeder[528]: [2022-03-28 10:01:40]  Data sent: 211.5 KB
Mar 28 10:01:40 raspberry rbfeeder[528]: [2022-03-28 10:01:40]  Data received: 0 B
Marco@raspberry:~ $ less /var/log/rbfeeder.log
[2022-03-25 09:18:06]  Starting RBFeeder Version 1.0.7 (build 20220125172500)
[2022-03-25 09:18:06]  Using configuration file: /etc/rbfeeder.ini
[2022-03-25 09:18:06]  Network-mode enabled.
[2022-03-25 09:18:06]           Remote host to fetch data: 127.0.0.1
[2022-03-25 09:18:06]           Remote port: 30005
[2022-03-25 09:18:06]           Remote protocol: BEAST
[2022-03-25 09:18:06]  Using GNSS (when available)
[2022-03-25 09:18:06]  Start date/time: 2022-03-25 09:18:06
[2022-03-25 09:18:06]  Socket for ANRB created. Waiting for connections on port 32088
[2022-03-25 09:18:07]  Connection established.
[2022-03-25 09:18:18]  Could not start connection. Timeout.
[2022-03-25 09:20:36]  Starting RBFeeder Version 1.0.7 (build 20220125172500)
[2022-03-25 09:20:36]  Using configuration file: /etc/rbfeeder.ini
[2022-03-25 09:20:36]  Network-mode enabled.
[2022-03-25 09:20:36]           Remote host to fetch data: 127.0.0.1
[2022-03-25 09:20:36]           Remote port: 30005
[2022-03-25 09:20:36]           Remote protocol: BEAST
[2022-03-25 09:20:36]  Using GNSS (when available)
[2022-03-25 09:20:37]  Starting RBFeeder Version 1.0.7 (build 20220125172500)
[2022-03-25 09:20:37]  Using configuration file: /etc/rbfeeder.ini
[2022-03-25 09:20:37]  Network-mode enabled.
[2022-03-25 09:20:37]           Remote host to fetch data: 127.0.0.1
[2022-03-25 09:20:37]           Remote port: 30005
[2022-03-25 09:20:37]           Remote protocol: BEAST
[client]
network_mode=true
key=xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
[dump978]
#dump978_enabled=false
  • CYYZ - Toronto
Re: Reinstalled and refuses to work !!!!!
« Reply #1 on: March 28, 2022, 04:07:09 PM »
Check you rbfeeder key you have entered in file /etc/rbfeeder.ini
Code: [Select]
sudo systemctl stop rbfeeder
sudo rbfeeder --setkey ‹your sharing key›
Does last command outputs that "connection accepted by AirNav server", and prints your station number EXTRPIxxxxxx ?
If it does, press Ctrl and C keys togather, then issue following command
Code: [Select]
« Last Edit: March 28, 2022, 04:11:29 PM by abcd567 »
zxenith
« Reply #2 on: March 29, 2022, 01:39:29 AM »
It looks like you are in network mode
If you only want to feed to Rbox then Run
sudo rbfeeder --set-network-mode off --no-start
If you are also running MM2
Then this is an example of the correct formatting (use your own keys, long lat )
[client]
network_mode=false
key=aaaaaaaaaaaaaaaaaaaa
sn=E111111111
lat=11.111111111
lon=-111.1111111111
alt=11
[network]
mode=beast
external_port=30005
[mlat]
autostart_mlat=true
[dump978]
For MM2 config example (use your own long lat, and .sqb optional )
--location 11.1111111111:-111.111111111
--inConnectId 127.0.0.1:30004:ADSB
--inConnectId 127.0.0.1:30105:MLAT
--db /home/pi/DATA/BaseStation.sqb <---only if you have
–-db /home/pi/data/flightroute-icao.sqb <----only if you have
--web 8787
« Reply #3 on: March 29, 2022, 02:06:46 AM »
amazing... now I want to post and get this message...
CleanTalk: *** Forbidden. Please enable JavaScript. Contains contacts. Message seems to be spam. ***
  • CYYZ - Toronto
« Reply #4 on: March 29, 2022, 02:50:08 AM »
[client]
network_mode=false
sn=E111111111
lat=11.111111111
lon=-111.1111111111
alt=11
[network]
mode=beast
external_port=30005
[mlat]
autostart_mlat=true
[dump978]
--web 8787
As I understand, @Av8tor_from_Argentina is already feeding FR24 and Flightaware. That mean either dump1090-fa or dump1090-mutability is installed and running and producing beast format data on port 30005.
In above condition "network_mode=true" is 100% correct setting. With this setting, the rbfeeder will use the beast data at port 30005 of dump1090-fa or dump1090-mutability.
If setting is changed to "network_mode=false", the integral dump1090-rb of rbfeeder will start. Now there will be two dump1090 running, with only one Dongle available. This will cause conflict and failure.
Please do not use network_mode=false if you already have installed dump1090-fa or dump1090-mutability.
.In case you want to run Radarbox24's dump1090-rb, you must first uninstall other dump1090 (fa or mutability) and only after that change setting to "network_mode=false".
« Last Edit: March 29, 2022, 03:31:36 AM by abcd567 »
zxenith
« Reply #5 on: March 29, 2022, 04:49:29 PM »
Thank you for the clarification
« Reply #6 on: March 30, 2022, 08:08:35 PM »
Good evening. I only have DUMP1090-fa installed and running. Network mode is false...
What else to try ?
Is there any series of commands in order to see why RB denies to connect?
Why FR and FA works fine ???
IN FR windowed status page:
FR24 Link:   Connected via UDP
FR24 Radar Code:   T-SADP31
Local IP(s):   192.168.1.106, xxxxxxxxxxx
Aircraft Tracked:
(ModeS & ADS-B)   11
Aircraft Uploaded:   8
Receiver:   beast-tcp, Connected
MLAT running:   YES
« Last Edit: March 30, 2022, 08:10:48 PM by Av8tor_from_Argentina »
« Reply #7 on: March 30, 2022, 08:43:00 PM »
abc stated
While running dump1090-fa you should have network mode=true
« Reply #8 on: March 31, 2022, 08:15:11 PM »
[client]
network_mode=true
key=6a8aaxxxxxxxxxxxxxxxe39
[network]
mode=beast
external_port=30005
[mlat]
autostart_mlat=true
[dump978]
« Reply #9 on: April 01, 2022, 12:50:32 AM »
not a single response. Uninstalled and reinstalled again.. NOTHING, NADA, ZERO...
  • CYYZ - Toronto
« Reply #10 on: April 01, 2022, 01:05:16 AM »
Please post output of following commands:
Code: [Select]
apt-cache policy rbfeeder
Code: [Select]
sudo rbfeeder --setkey xxxxxxxxxxxxxxxxx
(In above comand, replace xxxxxxxxxxxxx by your actual key)
« Last Edit: April 01, 2022, 06:32:06 AM by abcd567 »
« Reply #11 on: April 01, 2022, 11:08:31 AM »
Marco@raspberry:~ $ apt-cache policy rbfeeder
rbfeeder:
  Installed: 1:1.0.7
  Candidate: 1:1.0.7
  Version table:
 *** 1:1.0.7 500
        500 https://apt.rb24.com bullseye/main armhf Packages
        100 /var/lib/dpkg/status
Marco@raspberry:~ $ sudo rbfeeder --setkey "station identifier"
[2022-04-01 08:02:20]  Starting RBFeeder Version 1.0.7 (build 20220125172500)
[2022-04-01 08:02:20]  Using configuration file: /etc/rbfeeder.ini
[2022-04-01 08:02:20]  Network-mode enabled.
[2022-04-01 08:02:20]           Remote host to fetch data: 127.0.0.1
[2022-04-01 08:02:20]           Remote port: 30005
[2022-04-01 08:02:20]           Remote protocol: BEAST
[2022-04-01 08:02:20]  Using GNSS (when available)
[2022-04-01 08:02:20]  Start date/time: 2022-04-01 08:02:20
[2022-04-01 08:02:20]  Socket for ANRB created. Waiting for connections on port 32088
[2022-04-01 08:02:21]  Connection established.
[2022-04-01 08:02:31]  Could not start connection. Timeout.
again same response from system
  • CYYZ - Toronto
« Reply #12 on: April 01, 2022, 05:06:00 PM »
Did you first remove rbfeeder, then install a fresh copy?
OR
Did you install a fresh copy over existing copy?
Seems reinstall did NOT remove some corrupted files of old install.
Please do this to first purge the existing install, then install a fresh copy:
Code: [Select]
sudo apt purge rbfeeder
sudo rm /etc/rbfeeder.ini
sudo apt update
sudo apt install rbfeeder
« Last Edit: April 01, 2022, 05:10:59 PM by abcd567 »
« Reply #13 on: April 02, 2022, 02:25:36 AM »
CleanTalk: *** Forbidden. Please enable JavaScript. Contains contacts. ***
Why I receive this message every time that I try to paste a series of commands and their response... ????
  • CYYZ - Toronto
« Reply #14 on: April 02, 2022, 07:27:39 AM »
(1) Which browser you are using? Use another browser.
(2) You keep on saying your OS is bullseye, without telling which bullseye. There are three bullseys
- Raspberry Pi OS Bullseye
- Armbian OS Bullseye
- DietPi OS Bullseye
Your command prompt is "Marco@raspberry:~ $".
This command prompt is not the default command prompt of any of the above OS, and gives no indication which of above OS you are using.
Please note that your rbfeeder is unable to connect to AirNav server. This connection  problem is specific to DietPi OS.
Please tell us which one of above three listed OS is your OS.
