Author Topic: Grounding ADS-B antenna  (Read 7992 times)
jwyman
    • Southern Maryland Weather
« on: April 14, 2022, 03:09:18 PM »
After doing some research and getting advice from expert HAM radio operators, it appears that you need to ground the ADS-B antenna IF:
The center conductor is NOT grounded to the shield of the coax/connector..
If the center conductor IS tied to the ground then no ground is necessary.
I purchased this little unit and installed with no appreciable degradation in signal..
