'my log'entries
Started by besty, June 30, 2008, 06:19:28 PM
besty
Do any changes or entries into 'my log' have any effect on the database? it would be a lot easier to alter or input new details on this screen rather than having to go looking for it in the database to edit or enter.
No they don't, because this is a record of Live aircraft you have detected.  You don't want this to change the main database as this is a historical record.
besty
#2
True but it seems a bit long winded to add or change any details, having to find them first on the database. There should be some quick way of adding or changing details. the SBS has a seperate reporter program that lets you work on the database. This would be easier than having to open and close the explore database window whenever you want to see what's going on you could just put it behind the RB window till you want it again but it would still be available and open for use.
The reporter program is nothing more than a database viewer - it opens the SQB file for viewing and editing. The database editor in RadarBox is essentially the same thing except in runs within RadarBox.
There are other free software around which can do similar outside RadarBox.
besty
Thats what i mean if you are using the sbs version you can keep it open at all times but behind your window when you aren't bust working on it. Rather than the RB version where you have to close it to see what's going on. Easier to minimize the sbs version, nothing wrong with rb version just a bit more awkward to get used too. I like the option of having them both open together so I can work on it when things get quiet for a few minutes, without having to open it and find what i'm looking for.
