piaware rbfeeder, no data
Started by Dreamglider, June 06, 2022, 02:50:18 PM
Dreamglider
i have 3x Rpi's running PiAware feeding data to flightaware, planefinder, Flightradar and adsbexchange.
i also have rbfeeder installed and claimed on all 3 but the website says only "No data" (The other sites are all getting good data)
what am i doing wrong ?
thanks
I would imagine this tread will help
Dreamglider
what tread would that be ?
edited*
#4
Quote from: Dreamglider on June 06, 2022, 02:50:18 PM
Please post output of following commands
Note: replace your feeder keys,  latitude and longitude by xxxxx when posting in forum.
cat /etc/rbfeeder.ini
cat /etc/fr24feed.ini
sudo systemctl status dump1090-fa
Dreamglider
pi@piaware:~ $ cat /etc/rbfeeder.ini
[client]
network_mode=false
key=sdvsdvsdvsdvsdvsdvsdvsdvsdv
sn=sdsdsdsdvsdvvsdvsd
lat=61
lon=-6
alt=35
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
[dump978]
#dump978_enabled=true
pi@piaware:~ $ cat /etc/fr24feed.ini
receiver="avr-tcp"
fr24key="wefwefwefwefwef"
host="127.0.0.1:30002"
bs="no"
raw="no"
logmode="2"
logpath="/var/log/fr24feed"
mlat="yes"
mlat-without-gps="yes"
pi@piaware:~ $ sudo systemctl status dump1090-fa
● dump1090-fa.service - dump1090 ADS-B receiver (FlightAware customization)
     Loaded: loaded (/lib/systemd/system/dump1090-fa.service; enabled; vendor preset: enabled)
     Active: active (running) since Mon 2022-06-06 05:17:11 WEST; 20h ago
       Docs: https://flightaware.com/adsb/piaware/
   Main PID: 546 (dump1090-fa)
      Tasks: 1 (limit: 2059)
        CPU: 10min 45.336s
     CGroup: /system.slice/dump1090-fa.service
             └─546 /usr/bin/dump1090-fa --quiet --device-type none --fix --lat 61 --lon -6 --max-range 360 --net-ro-port 30002 --net-sbs-port 300>
Jun 06 05:17:11 piaware systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
Jun 06 05:17:13 piaware dump1090-fa[546]: Mon Jun  6 05:17:13 2022 WEST  dump1090-fa 7.2 starting up.
Jun 06 05:17:13 piaware dump1090-fa[546]: Net-only mode, no SDR device or file open.
lines 1-13/13 (END)
#6
==== RB24 FEEDER - Stting is wrong ====
(1) Open file rbfeeder.ini to edit by following command:
sudo nano  /etc/rbfeeder.ini
(2) In file opened, make change as shown in RED
(i.e. change "network_mode=false" to "network_mode=true")
[client]
network_mode=true
lat=61
lon=-6
alt=35
[network]
mode=beast
external_port=30005
[mlat]
autostart_mlat=true
[dump978]
(3) Save file  (Ctrl+O) and after saving, close (Ctrl+x)
(4) Restart RB24 feeder
===== DUMP1090-FA - Setting is wrong =======
Quote
(5) Setting is wrong. Please issue following commands to correct it:
sudo piaware-config receiver-type rtlsdr
sudo systemctl restart piaware
sudo systemctl restart dump1090-fa
(6) REBOOT PI
sudo reboot
