MLAT seems running but no sychro/data
Started by F4HUX, June 23, 2022, 08:25:35 AM
F4HUX
Quote from: Runway 31 on June 23, 2022, 02:44:12 PM
Are you logged in to your account.  It may be that the receiver is not linked to your account, it usually linked in a short period of time automatically so contact support with your station number and the email address of your account and ask them to link them
Once done you should be able to amend your lat/lon and should have MLAT
Yes I am logged into my account but I don't see my receiver. I'll contact support tomorrow .
Many thanks.
Pierre
F4HUX
F4HUX
In progress
sudo nano /etc/rbfeeder.ini
add line :
lat=my lat
lon=my lon
alt= my alt
save
sudo systemctl restart mlat-client
It's running but.....see screenshot.
Pierre
F4HUX
I believe it is due to your account not being linked.  As a feeder if you click Account/Profile you should have a Business Plan, is that the case
F4HUX
In progress ... ;)
So I'll contact support to link my profile and my feeder.
See you later
Pierre
F4HUX
#20
@F4HUX
Although your mlat problem is solved, I am curious to know which dump1090 you are running. From your output below it is clear it is NOT dump1090-fa.
huawei@ubuntu-server:~$ sudo systemctl status dump1090-fa
[sudo] Mot de passe de huawei :
Unit dump1090-fa.service could not be found.
I first thought you are running dump1090-mutability, but the top command screenshot of Ubuntu Server says only "dump1090", does not say "dump1090-mutability.
Quote from: F4HUX
connection to dump1090 running on ubuntu-server (ip =192.168.0.101)
Quote from: F4HUX
top command on ubuntu-server
SCROLL RIGHT TO SEE THE RIGHT-MOST COLUMN OF SCREENSHOT
Can you please issue following command on your Ubuntu Server and post the output?
sudo apt-cache policy dump1090-mutability
F4HUX
#21
Hello abcd567
It' s antirez' s version
https://github.com/antirez/dump1090
my dump1090.sh in my crontab
cd /home/huawei/dump1090
./dump1090 --device-index 1 --interactive --net --ppm 1 &
huawei@ubuntu-server:~$ sudo apt-cache policy dump1090-mutability
dump1090-mutability:
  Installé : (aucun)
  Candidat : 1.15~20180310.4a16df3+dfsg-6
Table de version :
     1.15~20180310.4a16df3+dfsg-6 500
        500 http://fr.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
Good evening
Pierre
F4HUX
ps : thanks to the support
wiedehopf
You'll see significantly improved reception switching to dump1090-fa or readsb.
Deactivate the crontab, reboot and install:
https://github.com/wiedehopf/adsb-scripts/wiki/Automatic-installation-for-readsb
It's simple and the feed clients will keep working as they are as the same ports are provided.
AVR on 30002
beast on 30005
SBS on 30003
F4HUX
Quote from: F4HUX on June 23, 2022, 02:45:22 PM
Thanks you for this information . I 'll try to replace dump1090 with  readsb  after read your github website
Perhaps I'll drop cubieboard and try to install docker (version github for rbfeeder for amd64: Linux x86-64) on my ubuntu-server20.04
Have a good afternoon.
Pierre
F4HUX
Yes !  I'll do.
Pierre
Quote from: F4HUX on June 24, 2022, 06:56:49 PM
Hello abcd567
  Installé : (aucun)
Table de version :
Good evening
Pierre
F4HUX
Thanks for the detailed info.  I did not expect you are using the very original,  the very first dump1090 - the Antirez version.
Hats off to Antirez who created the original dump1090. Now it's various branches & versions dominate the adsb decoder world.
