Author Topic: MLAT seems running but no sychro/data  (Read 20032 times)
F4HUX
« on: June 23, 2022, 08:25:35 AM »
Hello
 my station : https://www.radarbox.com/stations/EXTRPI139763
 Rbfeeder is on a cubieboard but the flightaware Usb stick pro is on a other machine (ubuntu2004).
Mlat seem's running (you can see below)
pierre@cubieboard2:~$ apt-cache policy mlat-client
mlat-client:
  Installé : 0.2.11+deb11
  Candidat : 0.2.11+deb11
 Table de version :
 *** 0.2.11+deb11 500
        500 https://apt.rb24.com bullseye/main armhf Packages
        100 /var/lib/dpkg/status
pierre@cubieboard2:~$ sudo systemctl status mlat-client
● mlat-client.service - LSB: Multilateration client
     Loaded: loaded (/etc/init.d/mlat-client; generated)
     Active: active (exited) since Wed 2022-06-22 16:37:55 CEST; 17h ago
       Docs: man:systemd-sysv-generator(8)
    Process: 961 ExecStart=/etc/init.d/mlat-client start (code=exited, status=0/SUCCESS)
        CPU: 117ms
Warning: journal has been rotated since unit was started, output may be incomplete.
But no synchro. Perhaps, my lat an long are wrong , but I can't see where I can check ?
My address is good in my settings.
I use chrony
pierre@cubieboard2:~$ chronyc tracking
Reference ID    : 5BE09529 (eva.aplu.fr)
Stratum         : 3
Ref time (UTC)  : Thu Jun 23 07:49:53 2022
System time     : 0.000215189 seconds slow of NTP time
Last offset     : -0.000547806 seconds
RMS offset      : 0.000208354 seconds
Frequency       : 31.478 ppm fast
Residual freq   : -0.025 ppm
Skew            : 0.032 ppm
Root delay      : 0.044707321 seconds
Root dispersion : 0.022932839 seconds
Update interval : 1042.8 seconds
Leap status     : Normal
Have you same ideas ?
Many thanks
Pierre
F4HUX
Re: MLAT seems running but no sychro/data
« Reply #1 on: June 23, 2022, 09:13:40 AM »
Did you reboot the computer after installation, if not try rebooting
Please post output of following commands
Note: replace your feeder keys,  latitude and longitude by xxxxx when posting in forum.
Code: [Select]
cat /etc/rbfeeder.ini
cat /etc/fr24feed.ini
sudo systemctl status dump1090-fa
« Last Edit: June 23, 2022, 09:16:55 AM by Runway 31 »
F4HUX
« Reply #2 on: June 23, 2022, 10:28:20 AM »
On cubieboard
pierre@cubieboard2:~$ cat /etc/rbfeeder.ini
[client]
key=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
sn=EXTRPI139763
network_mode=true
[network]
mode=beast
external_port=30005
external_host=192.168.0.101
[mlat]
autostart_mlat=true
mlat_cmd=/usr/bin/python3.9 /usr/bin/mlat-client
[dump978]
#dump978_enabled=true
On ubuntu20.04 (ip = 192.168.0.101)
huawei@ubuntu-server:~$ cat /etc/fr24feed.ini
receiver="avr-tcp"
fr24key="xxxxxxxxxxxx"
host="127.0.0.1:30002"
bs="no"
raw="no"
logmode="0"
windowmode="0"
logpath="/var/log/fr24feed"
mpx="no"
mlat="no"
mlat-without-gps="no"
huawei@ubuntu-server:~$ sudo systemctl status dump1090-fa
[sudo] Mot de passe de huawei :
Unit dump1090-fa.service could not be found.
2 weeks ago, FR24 information by mail :
Important! If you are sharing to other networks alongside Flightradar24, please disable MLAT.
When the installation is complete, please make the change in either the Raspberry Pi’s Web UI or edit the fr24feed.ini config file, please.
MLAT=“no”
MLAT-without-gps=“no”
pj screen shot of FlyghtAware
wiedehopf
« Reply #3 on: June 23, 2022, 11:38:11 AM »
No MLAT on FA either?
Are you running my readsb by chance? https://github.com/wiedehopf/adsb-scripts/wiki/Automatic-installation-for-readsb
It can show when data on the USB bus gets lost, this is usually the cause of MLAT issues.
(check the log as described in the readme on the link above)
Does adsbexchange MLAT work? :)
« Reply #4 on: June 23, 2022, 12:28:43 PM »
The MLAT client seems to be ok however, try changing as follows
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
Also I dont see any mention of your lat/lon/altitude have you entered them correctly
Due to a bug in the MLAT client restarting  by "sudo systemctl  restart rbfeeder" does NOT solve make mlat to work. Only Rebooting RPi makes mlat to work
« Last Edit: June 23, 2022, 12:41:04 PM by Runway 31 »
F4HUX
« Reply #5 on: June 23, 2022, 01:05:30 PM »
top command on ubuntu-server
wiedehopf
« Reply #6 on: June 23, 2022, 01:27:57 PM »
Well is adsbexchange MLAT synced?
https://map.adsbexchange.com/mlat-map/
What's the station name?
Change the decoder to readsb, it gives better logging for problematic SDRs.
(https://github.com/wiedehopf/adsb-scripts/wiki/Automatic-installation-for-readsb)
I'll probably also give you a small improvement in reception compared to dump1090-mutability.
It has the same ports open as dump1090.
Again the most common issue is not enough voltage getting to the SDR, for example due to USB extensions or insufficient RPi power supplies.
« Last Edit: June 23, 2022, 01:35:28 PM by wiedehopf »
F4HUX
« Reply #7 on: June 23, 2022, 01:38:54 PM »
[network]
mode=beast
external_port=30005
In rdfeeder.ini ? but no usb dongle on cubie. connection to dump1090 running on ubuntu-server (ip =192.168.0.101)
Quote
where enter my lat/long ?  nowhere in my account/profile . I must write my Lat/Long in rbfeeder.ini ?
Quote
 ok. I understand
F4HUX
« Reply #8 on: June 23, 2022, 01:41:31 PM »
LFJR
# synced peers: 24 Sync stats
Region: Southern Europe, France, Middle East, Africa (5C)
Closest peer: 59.5 km (37.0 miles)
Farthest peer: 254.9 km (158.4 miles)
Approximate location: 47.63, -0.52
« Reply #9 on: June 23, 2022, 01:51:40 PM »
ok my error on network, I thought you were using it solely for RB I wasnt aware the feed was from FA/server
I will leave the suggestions to people who know Linux
« Reply #10 on: June 23, 2022, 01:57:04 PM »
On your station page https://www.radarbox.com/stations/EXTRPI139763 see the grid top left, click on Edit your location and enter your exact lat/lon
wiedehopf
« Reply #11 on: June 23, 2022, 02:23:36 PM »
Just to make it clear, the following is not about the rbfeeder MLAT but rather about generally improving the station.
The range is nice but the message rate is suboptimal.
Again, using a more current decoder like dump1090-fa or readsb can help with that.
You could also consider a filter or a uputronics filtered preamp.
Generally for MLAT it's good to give the position as precise as possible (5 decimal digits).
Might not hurt to check FA / adsbexchange: https://www.freemaptools.com/elevation-finder.htm
FA has it on the statistics page i believe, for adsbexchange it's easiest to just rerun the feeder install to put in a precise position.
F4HUX
« Reply #12 on: June 23, 2022, 02:24:45 PM »
Sorry  Alan but.....I can't click on "edit"   ;)
« Reply #13 on: June 23, 2022, 02:44:12 PM »
Are you logged in to your account.  It may be that the receiver is not linked to your account, it usually linked in a short period of time automatically so contact support with your station number and the email address of your account and ask them to link them
Once done you should be able to amend your lat/lon and should have MLAT
F4HUX
« Reply #14 on: June 23, 2022, 02:45:22 PM »
I am Hamradio, and I use https://www.egloff.eu/googlemap_v3/carto.php (6 decimal digits) using direwolf (APRS)
Thanks you for this information . I 'll try to replace dump1090 with  readsb  after read your github website
Perhaps I'll drop cubieboard and try to install docker (version github for rbfeeder for amd64: Linux x86-64) on my ubuntu-server20.04
Have a good afternoon.
Pierre
F4HUX
« Last Edit: June 23, 2022, 02:52:33 PM by F4HUX »
