Author Topic: Hardaware not connected  (Read 18973 times)
Bob60
« on: June 25, 2022, 09:32:40 AM »
Hi, I'm writing from Italy, I have a FlightStick, the Airnav radarbox software says "hardware not connected" but I have no driver problems, the stick, if I open the RTL10190 software, perfectly receives the aircraft in flight. is it a software setting problem? Thanks for the help!
Roberto
Re: Hardaware not connected
« Reply #1 on: June 25, 2022, 01:41:05 PM »
Using the V6.0.03 software, connect via your home network, set up the network connection using File/Preference on one of the tabs in their with you network credentials.  I cannot remember which tab as I use V6.01.01 in  Windows
« Last Edit: June 25, 2022, 02:07:59 PM by Runway 31 »
Bob60
« Reply #2 on: June 27, 2022, 09:15:33 AM »
Hi Alan, thanks for the reply, but I didn't understand the talk about the LAN network, my flightstick is connected directly to the PC via USB and I'm using Air Nav Radarbox 6.02.003. Should I use another version or is this okay? however the driver works but the software does not see the usb key :-(
Roberto
« Reply #3 on: June 27, 2022, 11:58:45 AM »
Ah sorry I thought you were on a  Raspberry Pi when you mentioned RTL1090.  Did you install the flightstick drivers https://www.airnavsystems.com/Download/ANRB/Drivers/microRadarbox-Drivers-20150411.exe
If you have and its still not connecting use Zadig drivers https://zadig.akeo.ie/
V6.3 is designed for use with the xrange receiver, you would be better with v6.02 as a few new bugs were introduced with it https://www.airnavsystems.com/download/ANRB/ANRB60002Setup.exe
Bob60
« Reply #4 on: June 27, 2022, 03:29:27 PM »
Thanks solved! :-)
Roberto
« Reply #5 on: June 27, 2022, 04:22:54 PM »
Cheers Bob, no problem
law1979
« Reply #6 on: June 28, 2022, 01:45:58 PM »
I have the exact same problem.
I can see data in the RTL10190 software.
In Airnav software : "hardware not connected".
Im using version 6.02.
How did you solve the problem please ?
Chris
« Reply #7 on: June 28, 2022, 02:36:30 PM »
I presume by installing the flightstick divers either the Airnav ones or the Zadig ones.  Have you installed the drivers?
law1979
« Reply #8 on: June 28, 2022, 03:11:29 PM »
Yes, i first installed the airnav drivers, then the zadig ones.
uninstalled airnav software, reinstalled.
Thanks.
Chris
« Reply #9 on: June 28, 2022, 04:16:11 PM »
Do you see it in devices and printers under unspecified?  How are its properties?
Try unplugging the stick and plugging it back in, also try another USB port
« Last Edit: June 28, 2022, 05:31:54 PM by Runway 31 »
law1979
« Reply #10 on: June 30, 2022, 07:37:43 AM »
Its working now
uninstalled the driver, reinstalled zadig driver.
Thnak you !
« Reply #11 on: June 30, 2022, 01:10:53 PM »
Great, good news
NHSARainer
« Reply #12 on: July 03, 2022, 09:45:58 PM »
I am having the same problem that RadarBox v6.02.003 does not connect to my USB flightstick.
It does connect to dump1090 and I can see the filght around my antenna on VirtualRadar v2.4.4 problrm free ...
What am I doing wrong ?
I have also a RTL-SDR dongle running for another use. is there a Serial # conflict ?
Thanks for any help
regards Rainer
Grüße Rainer
EXTSHA196530
NHSARainer
« Reply #13 on: July 03, 2022, 10:31:21 PM »
I have a conflict between my RTL-SDR dongle and the RadarBox Flightstick
How can I define which dongle uses RadarBox v6.2.003 ?
Thanks Rainer
« Last Edit: July 03, 2022, 10:43:58 PM by NHSARainer »
Grüße Rainer
EXTSHA196530
« Reply #14 on: July 04, 2022, 09:20:12 AM »
NHS Rainer
You will need to change the serial number of the sticks to avoid conflicts, see this thread https://forum.radarbox24.com/index.php?topic=105891.0
